You might need a consult3 or a decent clone to read the TCU codes.. my nissan datascan adaptor won't read the TCU in my wife's J31 maxima.. so I would assume it wouldn't read the TCU in V35 either.
p1065 check fuse in engine bay its 15a says inj emg cont had that code couple days ago and changed fuse and no more engine light.I have got scanner for the v35 if u want bring to me can scan for you or reset codes.
Hey man,
Where abouts are you located?
I dont want to drive the car as it did give off a little bit of a burning smell when I got home :(
Im happy to pass you a 6-pack or something in exchange for your scanning tool services
Any idea if your scanner will scan for gearbox errors?
I dont think P1065 is related to the gearbox at all
Im going to check oil level, colour and how dirty it is, and see if its contaminated with coolant
I have spoken to Auto Japan who was very helpful, unfortunately will not touch cvt gearboxes :(
Ive been advised to take it to a Nissan dealer *fingers crossed one of them are willing to help*
Hey man,
Im in orelia.Dont take it to nissan,try C-red tunning or tokyo motorsports.Change trans oil and change the fuse for the ecm ive found that 1 thing on the v35 cant affect heaps things.Yes my scanner will scan for trans error,s
My is getting worst too. First it had whine noise. Now and again it jumb and stop just in a morning.The funny thing is it still driveable. I got up 120km/h on Freeway. Just whine noise constancy there soon the wheels move
I had a look and noise come out from Trans. Took a housing off all bearings look OK but we don't want to open Trans yet
I am looking another car then this can play around
If you going to buy Oil try this : http://global.rakuten.com/en/store/onlinestore/item/10000682/?siteID=je6NUbpObpQ-c0cx1th_TZtg.yBDabPmoA
I got from them last time no issue
  • 2 months later...
The easier option is to purchase a 6mt conversion kit and sell the cvt transmission to cvt.nz. I am currently in process of conversion. If anyone will need assistance in future I will be writing step by step plan in more deapth than the current one I am following. Which can be located at the following infinity forum site http://g35driver.com/forums/drivetrain/345132-diy-5at-6mt-swap.html
Jezzza you may purchase the CVT out of my car if you like. Don't be concerned on price because I will sell it to you for less than the price of 4LT of cvt fluid. If you are interested still. Extroid Cvt model number is JR006E.. I guess you would have found this info out already.
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
