Hello I have a r32 gts-t
I am going to buy 550cc injectors and a larger fuel pump, bigger turbo, and supporting mods for tuning the car.
My goal is about 350-400 hp.
For now I am putting a rb 25 turbo on the car and upping the boost.
The car has full turbo back exhaust, pod and fmic.
When is a aftermarket fuel pressure regulator needed?
Stock will be fine for your plans.
FPR is about keeping pressure in the rail not flow. Choosing the right injectors means you should never have to change the fuel reg unless as stated you have an aftermarket rail and the stock one won't fit
Or when the bypass hole in the standard one isn't large enough to stop fuel pressure rising at light loads and idle with higher volume pumps . In theory any reg can close right up but standard ones can only open up so much .
A .
True in theory.
Do you have any examples of that occurring?
True in theory.
Exactly, even though the hole in the stock reg is small, it doesn't seem to cause the pressure to increase from my testing, even with the Walbro 460's at full noise. Perhaps with a 2000hp pump, but you would need new rail and reg with braided lines by that stage I think.
So the 460 walbro will support around 450rwkw on e85 and won't flow too much for the stock fpr?
and it's $200 brand new, sounds like a winner for most applications
And is long term e85 tolerant. It's a no-brainer for most applications, or until a surge tank is required, eg track work.
The only reason to "upgrade" the factory FPR is really in three instances:
1. When your injectors are starting to max out, but you don't want to upgrade them, so you bump up the rail pressure with the aftermarket adjustable fuel pressure regulator to push them a little but furthur. Obviously this isn't ideal and most people don't recommend it. Just buy the correct injectors to start with.
2. When you are running huge amounts of boost and the factory fuel pressure regulator can not keep up the 1:1 fuel pressure ratio. Therefore you will need an aftermarket fuel pressure regulator that can handle this high amount of boost pressure and keep up the 1:1 ratio.
3. The factory fuel pressure regulator has failed so you may choose to buy an aftermarket one however still run it at factory fuel pressure.
So as you can see, not many people fall into the second category because a lot of people don't run 2+bar of boost through their car. A few do fall into the first category because they may be on a budget and don't want to upgrade the stock injectors so they choose to bump the rail pressure up instead and obviously a few will fall into the third category.
However there is a fourth category that you will find 90% of people with aftermarket fuel pressure regulators fall into:
4. They have no idea what an adjustable fuel pressure regulator does, but they got told to buy one by a mate or read about one somewhere.
For your situation assuming that you are not running E85, your 700cc injectors should be fine for between 400-500HP therefore you do not need an aftermarket fuel pressure regulator.
Or 5: You want to lower the fuel pressure, as 40 psi base plus 40 psi boost is getting way too high. Most pumps have issues supplying fuel at 80psi+ pressure, lowering the base pressure will allow much greater fuel flow from the pump, as long as you didn't cheap out on undersized injectors.
  • Like 1
awesome, Even for track work though can't you just fill the tank to the top and not worry about surge? Or am I missing something
edit:
That's also a good point. I'd contact the injector manufacturer and see what they think about running less than 3Bar base. I wouldn't trust the spray pattern at that pressure without having them tested.
Or is that a waste of time?
Edited by Blackkers
edit:
My tank is 85L, you don't want that sort of extra weight in a track car.
3 bar is a lot, I run around 35psi base. Most injectors have issues opening consistently at high pressure too.
If you were running 40 psi boost I don't think low load spray pattern would be a concern at all!
Yeah, but remember that the delta P across an injector is constant (or at least it's supposed to be - rising rate fuel pressure regs or improper operation of the reg notwithstanding) at all loads. If you lower the pressure to keep the absolute pressure under control at high load, then it is also low at low load.
What you would want, if such a thing existed (and it does, just possibly not in the automotive field) is a falling rate reg.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
