if it runs better cold this could lead me to think that you have mixtures good with water temp correction....and they lean out when the corrections reduce as the water temp increases. as previously stated if you have the cable and software do some logging. checking mixtures would be a good idea....do you have a wideband?
  • 8 months later...
hey guys.. well its sorted, it was a faulty CAS.
Just incase someone else has a similar issues ... car would run fine when cold, and boost fine. When car was at running temperature the car would cough and pop in boost, but run fine just cruising.
Thanks
Good to hear you got it sorted, and thanks for updating the thread.
