Thanks for the responses. We'll the hta on twinscroll would be an even better combo would it not?
34geeteetee did you go from garrett gt3076r to hta 3076? And still happy with the results?
Are you running a single scroll 6boost low mount?
Edited by BlackBox
Yes it was a back to back swap with awesome results!
No mine is high mount.
Any particular reason you went high mount? What size compressor and turbine housing did you get?
Not really, i likes the way it looked in engine bays and figured it would be easier to work on... If i was to do it again i would have the turbo sitting further forward to make it easier to work on!
The housing is still a 4 bolt 0.82.
You'd probably get lower underbonnet temps and the dump etc is shorter and less obvious looking, but its a pain to fit ,
I was bit disappointed with the twin scroll, quite laggy in my case, maybe the use of twin gates would of made it more responsive im not sure but gave up on it.
Edited by AngryRB
Larger than gt3076? Did not realise this, hopefully will be all good :/
Yes, same size cover as the GT35... I thought i mentioned it but might not have :/
Are you on a stock manifold or aftermarket? (Sorry couldn't be bothered going back a few pages lol)
Low mount with a GT35 compressor cover? Good luck getting that to fit, 6Boost manifolds don't allow many turbo's even top mounted.
The twin gate setups are very tight... I would externally gate the turbine housing on the stock manifold if you are heading down the low mount route.
If your going to go a HTA 3076 twin scroll and wan't 330rwkw on pump fuel then I would suggest a T3 1.01 or T4 1.06 twin scroll ex hsg. I would also suggest a twin gate twin scroll manifold over a single ...so then the costs start adding up once the associated plumbing is also factored in.
Running a HTA3076 or even a GTX3076 on a .78 twin scroll hsg will just limit the top end potential of these turbos with potentially additional lag over the Garrett GT counterparts. The biggest GT30 turbo I would run with the .78 hsg on pump fuel would be a T56 GT3076 and event then I'd say it could limit the top end potential of that turbo. I'm not even sure I would run a GT30 size .78 twin scroll hsg on a RB 25 period given your hp goals on pump fuel.
I tried to find pics of the 6boost low mount design and i remember it had to have a bit of the engine mount shaved to fit the comp housing even on the GT3076...
I was going to still run one gate with the twin scroll,.. Would retaining the standard low mount leave more room than the 6 boost low mount? Had anybody heard of hta3076 on standard exhaust manifold?
Geeteetee did you have your 6 boost manifold before upgrading to your hta?
Are you saying the t3 1.01 twin? Or only t4 twin scroll beside t3 twin would be a restriction ?
yes mine was always high mount!
Twin scroll options aren't really available for them either...
Maybe a TS GTX3071 will be a better option for more response and fitting low etc?
Your call with running one gate on a twin scroll setup.
I'm saying either a T3 1.01 or T4 1.06 but you would need to buy the hsg separately such as from GCG or the like.
Personally, if it were my car and I was budget conscious I'd stick with a single scroll setup with the HTA 3076 and run a 3.5 inch dump back to the cat to get the turbo on boost as soon as possible.
I run a twin scroll twin gate setup on my SR20 and love it.....but money was of no concern to me.
Edited by juggernaut1
