"Darwin price" - hahahahahha.
Got to be kidding. Open speed limit, no local approved panel beating wshops for imports. Guys, cars cost a heap to insure up here. The major problem is getting a company to insure the imports in the first place. I have got a good deal through previous business done with Shannons, thats it.
Masa kit Primo? Looks like a winner.
Ken
I asked when I got my quote, it was ~$300 cheaper outside Sydney, Melbourne Brisbane etc. :D
  • Replies 99
SK,
I see you got your Stagea. Good stuff. Mine is now manual, has 3½ inch mandrel exhaust, Profec B boost controller, k&n pod filter, lowered suspension. Next to come are the igniter packs and power fc then turbo and fmic. wooo hooo i can't wait to have it all finished. I didn't get the chance to throw it on the dyno before the mods...... I couldn't wait!!!
Cheers
Gary
Jay,
Turbo to cat is slightly different because of the rear gearbox cross member, the exhaust needs to go closer to the passenger side of the car by about an inch. The centre is slightly longer than 33, the centre muffler is about 3 - 4 inches further back. The rear section is different because the wagon is longer from the rear of the fuel tank to the rear bumper by nearly 6 inches.
The short answer is I got a custom one made.....
Cheers
Gary
Hi Guys, having finished with the DOTARS bureaucracy, I am now dealing with the effen RTA bureaucrats.
It's all my fault, I made a big mistake, I paid for my greenslip on line :wassup:
Me = "It is good enough for renewing, so it must be good enough for first time rego?". :angel:
RTA = "Didn't you know that when registering a car for the first time you have to have the original of the greenslip with you". :bs!:
Me = "Well the NRMA let me do my greenslip on line and one of their questions is "is this a first time rego?". I have the screen printed receipt with the policy number and the receipt number and the vin number of vehicle". :rofl:
RTA= "No, the receipt number from the NRMA and the policy number aren't good enough." "There are other numbers on the :worship:ORIGINAL greenslip that we need."
Me= "I have the NRMA on my mobile now, what numbers do you want?" :Pimp2:
RTA = "listen, I told you, we need the original of the greenslip." :throwup:
Me ="Why?" :headspin:
RTA = "That's the system" :Bang:
So now I have to wait until the original greenslip is posted out to me by the NRMA.
SK,
Cheers
Gary
Hi Gary, was that differences to a GTR exhaust or a GTST exhaust?
Time for an update..............
Two weeks working interstate, so down to the RTA with the ORIGINAL greenslip.
RTA= "All the paperwork is now in order"
Me = "Great where's my rego?" :(
RTA = "Bad luck, you have been selected for a random inspection"
Me = "No problems, let's go" :cheers:
RTA = "Sorry, but you have to book it in"
Me = "Next Saturday?" :throwup:
RTA = " Sorry the Inspection Stations are only open Monday to Friday"
Me = "But I work" :D
RTA = "So XXXXday, at YYYYYYYYY"
Me = "Then they will register it?" :)
RTA = "On no, you will have to come back here to register it"
Me = "That means a whole day off work" :D
RTA = "Sorry, that's the system :Bang:
Time for the last update.....
Took the Stagea along for it's Identity Check.
Waited for 30 minutes in the que, I had an appointment but that doesn't matter.
Only took them 40 minutes to agree the engine and chasis numbers. :headspin:
Asked question " Must have been my bad luck getting a random inspection?' :boohoo:
RTA Inspector, "Oh no, we inspect ALL RAWS Imports for their first rego". :uzi:
"Why" :spew:
"It's the system" :Bang:
Went back to local RTA, waited in the que for 45 minutes. They finally took my money and I now have a registered Stagea ;)
Sk,
Sorry to hear about all the crap you had to go thru to get the rocket registered. But now it will be worth the wait. You will enjoy it.
Just fitted new bilstiens to her and now she really handles well. But unfortunately it raised the height a little, but hopefully that will sort itself out as it "beds in".
Next, is the brake upgrade and then the serious engine mods.
having trouble finding a Power FC for it though, so if anyone knows where to get one for the C34 Stagea please let me know.
cheers
Gary
Did you put them in yourself? I am looking into getting some bilsteins for the 32, just wondering what is involved with installing them (compared to the average shockie)....
Nothing :) They're a replacement strut, they're no different to a stocker in terms of putting it all in.
They're supplied with a new spring seat, all you need to do is swap over (or replace) the spring, bump stop, dust cover and the spring hat (the bit right at the top) and bolt it all into the car. So easy even I can do it :P
    • Z32 AFMs are 80mm tubes. RB26 AFMs are smaller. Just measure. Nismo RB26 AFMs have a different part number to original 26 ones. Probably also have a Nismo badge - but I don't know because I've never been near one. It's unlikely that they've been changed anyway.
    • Hey looking for pointers or experiences with indicator wiring/ common faults for the blinkers on the r31, I have a 87 silhouette and am having dramas with the blinkers staying on (not flashing) to indicate right,while trying to indicate this way the relay makes a constant noise, The front passenger side fender blinker is missing the harness connector to the bulb so is not connected would this effect the opposite side? Both rears work as they should, and blinker that stays on functions normally when on hazards instead of indicating, have replaced all bulbs,fuses and relay Cheers
    • I’ll check the AFM’s and confirm. I’ve seen on another forum post years ago it’s identified with an orange sticker and larger diameter. Unsure if I can check the diameter without removing the air filter. Is there a way to identify if the AFM is stock? I’ve done a quick search and it looks like it might be a green sticker instead?   Will try check that turbo core tag. Looks like a very tight fit in there. Do you know what number would show if it was a stock T25 turbo?
    • The car and the 33GT-R wheels look great. I can't remember if spacers were needed for these but the offset looks perfect for the GTS25t.
    • And the lack of ubiquitous availability. If it was less likely that I'd run out of fuel while trying to cross the crime zone, I'd probably be all over it.
