My R34 sits at 340mm front and 350/355mm at the back on Nismo S-Tune springs/shocks - no form of height adjustment in terms of adjustable circlips etc.
Ideally I'd like to drop the back 10/15mm as it bugs me how the back sits up a fraction, all the lines and styling on the 34 Sedan angle towards the front which highlights the back being just that bit higher.
Having had 4 different sets of adjustable suspension in my old 32, I can't think of anything to do other than replacing the rear springs.
The nismo shocks look to have a pretty standard spring seat so different springs should fit.
Anyone have any idea's how to achieve such a small drop easily? I can't think of anything other than replacing the springs?
https://www.sau.com.au/forums/topic/445373-lowering-the-back-of-my-r34-10mm/
Heat the springs up?
Yeah I thought about taking it to a spring/suspension place here and seeing if they can reset the height. For the hassle of taking them out I may as well replace the springs
Go Lovell's
If your happy with the ride then just drop some Lovell's in the back.
In my 34 GTT I liked the ride so just put shorter lovel's all round. The height dropped and only marginally stiffened the ride.
Feels really good :thumbsup:
- I can get you the part number if your keen. just PM me
I'll get a side on pic so you can check it out too
Edit: Mine were done by Capital Steering and Suspension in Canberra (best in town bar none).
Edited by Sinista32
Put a 10mm spacer into the front. Your handling will thank you for getting it up to a better height anyway.
Mmmm, never really thought of that. Does that sit on top of the strut? I've got plenty of thread on the nut even with the strut brace.
That would transfer a bit more weight to the back as well I'm guessing, which wouldn't hurt
34 GTT stock ride pretty high -> like a 4x4
would going higher than OEM introduce any instabilities or negatives?
let alone around a 4" gap between tyre and guard
Pic of stock height on 18"rims with a 35 profile tyre
Edited by Sinista32
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
