Ok so a few years back I purchased a Full Race twin scroll manifold. The manifold works great and my set up has exceeded expectations.
Only problem is that when I installed it my AC compressor no longer fitted as the lines that came out of it would foul on the manifold. I asked Geoff at full race about this problem and he said the manifold wasn't designed to work with the A/C on an R32 GTR (which sucks). Apparently there is now a revised manifold which allows it to work with the AC compressor.
Now I need some help problem solving so I can fix this and have delicious air con again. I guess the questions that need to be asked are...
what makes the 32 AC compressor/mounting bracket different from the 33 and 34, does the 32 bracket make the compressor sit higher?
Can I use a 33/34 bracket with a 32 compressor?
I guess if I come to the end of the road I can have a custom bracket made up so the compressor sits lower/away from the manifold.
Maybe if your reading this Geoff you could chime in with some advice.
thanks in advance
If the 32 bracket is different then that would be unusual. I've got an RB30 A/C bracket and my original RB26 bracket and they're identical. The more likely thing would be the compressor itself as in where the pipes come out of it and where they run. Without seeing a picture of how it sits you might be able to get an A/C workshop make up new pipes. If it is the compressor can you maybe get a 33 compressor?
Finally if all of that is useless then you may be able to make a "mount extension" that links the top mounting point of the compressor to the compressor mount. Basically a thick flat 'strip' of metal on each point that would still lock it in place but rotate the top of the compressor away from the engine and potentially away from the manifold. Sorry if none of that makes sense!
I faced the same issue with the SR version of the full-race twin scroll manifold too back in 2008/09.
I had a 6061 10mm ali plate made up which bolted onto the block at the original location and then had the plate heli-coiled about 25mm lower down (from memory) to accept the compressor bracket. Obviously you will need to adjust the positioning of the bracket to suite your compressor line clearance.
I also put heat sleeve over the aircon lines too. Six years later and no issues......well except for loss of licence :whistling:
Edited by juggernaut1
Apologies for my crap picture but a bracket like this might work to drop the compressor down a bit and out a bit (provided there is room around the compressor to do this. They generally run pretty close to the chassis rail though so you would have to work around that and go down further rather than out.
The blue bit is the bracket you would get laser cut. The grey bit is supposed to be the compressor!
Obviously any such bracket has to be made so that it keeps the fore-aft position of the compressor the same as original so the belt still lines up, but otherwise it's probably the best way to achieve the goal.
Of course, moving one pump probably means moving the other (PWR steer) also.....
  • Like 1
nissan-rb20-25-26det-t-twinscroll-turbo-
R32 compressor top R33 compressor bottom
Other way around, R33 compressor and lines on a R32 bracket
Pics and information from the full race website http://www.full-race.com/store/turbo-manifolds/nissan-rb20-25-26det-t-twinscroll-turbo-manifold.html
You know I've read that page I don't know how many times and I never once saw that note lol,
Must have been having a mans look.
if I can't get a hold of a 33/34 compressor for a decent price I may well make my own bracket like yours Ewan.
Judging by that pic I probably can't use my 32 lines a 33/34 compressor? :/
man u clown i had a 34 compressor in my garage with a bracket for like a year and sold it 2 months ago.. if u want to test fitment you can come take mine out of my car (its already disconnected) then you can test it, if all goes well u can buy another one
i had galvsport resolve this issue on my current build.
use some speedflow fittings to run the lines through the wheel well out of the way of the 6 boost. cost a few bucks but better than driving around in WA with no aircon
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
