Out of these 2 what do you think will run better/is better in a straight 6?
Just some info.......
HKS T51R SPL - 1000 PS Output
COMPRESSOR:
-Wheel- 56 Trim - 76.5 Inducer/ 102.2 Major
-Housing- 100 Inlet / 80 Outlet
TURBINE:
-Wheel- 76 Trim - 82.0 Major / 71.4 Exducer
-Housing- V-Band inlet / V-Band 115.5 mm outlet - 1.00 A/R
*Greddy.com currently un-available*
https://www.sau.com.au/forums/topic/44540-which-turbo/
both of them will run real shit in a RB24S an in line 6 cylinder carby engine. In fact you'd have lots of problems putting em on :D
For argument sake lets just assume you're not making stupid threads to pass time in the Automotive section, so henceforth from this post, lets just assume that this car has the necessary mods to support a 500hp+ system.
In which case I'd go the T51R Kai :D
BTW this topic's been covered before, you should really get used to using that search button up there.
https://www.sau.com.au/forums/topic/44540-which-turbo/#findComment-910354
the RB24S is a straight 6 engine, I was using it as an example to say that you need an engine that's got other mods to put the turbo on, and they greatly affect how the turbo runs. Also the main point I was trying to make is different inline 6's work differently with those 2 turbos.
?Make sense...
oh and for further reference I point you to this thread
https://www.sau.com.au/forums/topic/44540-which-turbo/#findComment-911762
So AnthonyK1... oops sorry, I mean WiDeBoI_2JZ
How's your brother's V8 R34 GTR going?
oH Jesus.........
1. I have allready talked about this
2. It was my bro who started all this so just drop the shit
3. Its a R33 GTS-t not a R34 GTR
4. It wont happen till next year
5. Its not my bro doing the switch
6. Wether u like it or not, my sis IS starting a mag
** some 1 said something about me in the wasteland about me and my mum getting me a R34 **
7. Even IF my mum got me a R34, i dont want it, i have been growing up since then, even if she got it i cant afford to run it. ie. petrol, insurance ect.
So look im asking for everyone to just be nice, kind and get along with me, if you do so i promise to never start a thread agian like those if i dont have proof to back it up.
Thank You.
https://www.sau.com.au/forums/topic/44540-which-turbo/#findComment-915466
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
