:) that sounds similar to what many brake places say about the V35 brakes.. 'one size fits all for non-bremo brakes'.. but that is also incorrect.. Series 2 and 3 brakes are larger than series 1, both front and rear.
No, the sports brake is normal...just big ass rotors....bigger than the normal brakes but not a bbk! Thats the confusing part...!! Cant seem to find anything locally...from America cost a big bomb. Prob gonna order the BBK and get it over with lol.
Yea Sonicii....do you think the smaller rotors would work alright with it anywya?
Edited by colin.ssc
Do you mean on the V35.. No.. they are a smaller diameter, so the pads will overhang then edge of the rotor..
No idea with the V36.
Only talking 10mm aren't we.. Given how cheap the 370Z discs are, even uprated ones, I reckon it might be worth a go.. It might be that the calipers are actually the same for both, just a slightly bigger disc and so with the 370Z pads as well, it might all line up correctly.
We might need to bite the bullet and ask GSL...
Edited by nickcorr
There is normally only a mm or so between the edge of the rotor and the edge of the area swept by the pad, so 10mm will be a problem..
I know first hand what you get if you put series1 V35 rear rotors on a series 2!. and there is a 16mm size diameter difference on the rear (24mm on the fronts)
http://www.skylinesaustralia.com/forums/topic/427462-2005-sedan-rear-brake-rotor-size/?hl=%2Bsedan+%2Brear+%2Bbrake+%2Brotor#entry6966153
oh yes, completly understand, not suggesting anyone just slaps on the smaller discs and drives off with an obvious pads not lining up problem.
Hence why I said to ask the experts, that being GSL. Still might be that with the correct pads, it all lines up... Stranger things have happened in OEM spare parts land before...
Whoever tries anything just be careful :)....especially the rear rotor is also 13" but thinner....fronts are 13" too but thicker. I've spoken to GSL a year ago...they don't have anything locally...they can import...cost $$...that is the only thing I dont like abt the PV36....loving the HR motor and 5spd....just the brakes are shitting me. Chose this over the 370GT never once thought abt brake size differ...lol
Wow!! That is incredable!! Someone at Nissan must have had a brain fade...
Is it even worth fitting the entire 370Z brakes from a wrecker rather than going with a BBK and having to change the wheels out to clear the calipers?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
