Wtb: Rims To Suit R33 Gts-T
It's new almost. Under a year old i think and I've tested it twice at supercheap
Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise. -
How old is the battery, it's more likely your battery is on its way out.
I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni! Argh! Steam cleaning has its place for sure.
