My PFC should be here in about a week for my RB25. Since these engines are very rare in the US I was wondering what kinda #'s I should tune it to. What's a good traget A/F ratio for the motor and what kinda timing do these motors like? Here is a list of my mods:
The car is a 92 240sx.
96 RB25DET series II.
Walbro fuel pump.
3" turboback exhaust with no cat.
T3/T04E turbo (56 trim compressor/.63 AR exhaust stage V wheel)
I have an FMIC for the car but it isn't on yet.
Right now I am running 9 psi with the stock ECU and it will hit fuel cut on cool nights. I have a wideband on the car now and I see the A/F's going to 10.8:1 under full boost. Base timing is set to stock (15 BTDC).
I was planning on running 12 psi (Should put me around 325-350 WHP) Maybe more to get those HP #'s
So what do these motors like for timing and fuel?
https://www.sau.com.au/forums/topic/44543-tuning-the-rb25det/
i have a motec on my r33, had it on the dyno the other day and you would not beleive how badly it ran at 10.8:1. Leaned it out and got most power at around 12.8:1 @ 10lb boost. The difference was staggering, seemed to be drowning it. Fuel economy at that A/F ratio was around 30l per 100 km hahaha.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
