Rb25Det Gearbox Fluid For Motorsport And Replacement Intervals
Ahh I see. I don't know, not all shocks are setup like that. Other than clearance it doesn't matter much because it is double wishbone, so ignore how it was and just out them in whichever way fits best
Aye, it has been pretty good since the shift ~ I just want access to the wiki ..again.. (now the mediawiki stuff has been updated), to get it all straightened out with consistent presentation (I talked to Session about it, turns out the mediawiki version was largely at fault..and pages created with older versions, etc etc)...I've basically given up asking, never get a reply...bit sad...but it is what it is.
Had a look at RHD Japan, I used them a lot back in the day and never had any troubles with them. The EUROSTER II CRUZ Reclinable Seats without the arm rests seem like a good seat for the street and comfort. $4,300 delivered for driver and passenger with rails seems like a good deal. Wonder if I can dodge the geee s teee? haha
This shows the bottom mount
Found this https://www.skylineowners.com/threads/coilover-fitting-help.143959/ Which says "there the fronts, long end goes in 1st, so nut and washer fits on short side." According to that the long, flared end goes towards the inside facing the suspension and the short side + washer goes on the outside. I installed it that way and it looks better that way as the coilover is spaced further away. There's no witness marks on the the old suspension or coilover, so it probably doesnt matter much. I'll see if i can find a photo
