Hi All
Question for any R34 owners out there. A while ago I fitted the Aero/Altia/Whatever you call it front bumper to my R34. This one came with the Foglights, as pictured.
Before this my car didn't have them fitted. So the foglights aren't wired up to anything.
I've also procured the switch for them that goes in near the headlight level adjuster (near right knee) (2nd pic, on left).
I like to keep things as clean and as factory as possible. I'd prefer to avoid having to hack in a custom loom to make them work, especially if the stock loom already has everything needed already there. There is a "fog lamp" fuse in the engine bay fuse box, which is live (20A). It looks as though the car's standard wiring loom has most if not all of the wiring, so I'm hoping this could be a simple plug-and-play affair. However I can't locate any of the wiring under the dash to hook into.
Does anyone have a R34 with these lights factory fitted and functional who could shed some light on where everything connects? Namely the switch, the lights themselves, whether or not there's any relays, and how the car behaves (eg, do the lights only come on with headlights, does the fog switch turn parkers/headlights on as well, etc).
Furthermore would there be anyone in Sydney with these lights who would let me have a poke around their car to work out how these are wired in? As you all probably know, there aren't any complete wiring diagrams floating around on the internet for these cars, so I'm forever having to poke around with a multimeter..
I have scoured the internet as best I can but the info I'm after just isn't out there.
Anyone able to help?
Thanks!
Edited by Rake
https://www.sau.com.au/forums/topic/445438-r34-fog-lights/
  • 1 month later...
  • 8 years later...
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
