Hi All
Question for any R34 owners out there. A while ago I fitted the Aero/Altia/Whatever you call it front bumper to my R34. This one came with the Foglights, as pictured.
Before this my car didn't have them fitted. So the foglights aren't wired up to anything.
I've also procured the switch for them that goes in near the headlight level adjuster (near right knee) (2nd pic, on left).
I like to keep things as clean and as factory as possible. I'd prefer to avoid having to hack in a custom loom to make them work, especially if the stock loom already has everything needed already there. There is a "fog lamp" fuse in the engine bay fuse box, which is live (20A). It looks as though the car's standard wiring loom has most if not all of the wiring, so I'm hoping this could be a simple plug-and-play affair. However I can't locate any of the wiring under the dash to hook into.
Does anyone have a R34 with these lights factory fitted and functional who could shed some light on where everything connects? Namely the switch, the lights themselves, whether or not there's any relays, and how the car behaves (eg, do the lights only come on with headlights, does the fog switch turn parkers/headlights on as well, etc).
Furthermore would there be anyone in Sydney with these lights who would let me have a poke around their car to work out how these are wired in? As you all probably know, there aren't any complete wiring diagrams floating around on the internet for these cars, so I'm forever having to poke around with a multimeter..
I have scoured the internet as best I can but the info I'm after just isn't out there.
Anyone able to help?
Thanks!
Edited by Rake
https://www.sau.com.au/forums/topic/445438-r34-fog-lights/
  • 1 month later...
  • 8 years later...
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
