G'day..I'm thinking of making a switch from a 290rwkw R34GTT to an EVO 7-9 when the right one comes up at the right price and right time...we will see....Currently running a Precision 5558 on 98 petrol and intending to run the EVO on 98 as a purely street daily car with 1-2 track days a year.
Question is -will a 250awkw EVO feel more crazy on the street and give much more excitement coming from a 290rwkw rwd r34??
250kw because that seems to be the EVOs sweet spot with mild mods and probably 300awkw with E85. I'm not a fan of going sideways, wheelspinning/ going nowhere and looking like an ass - I rather something that hooks up and is gone before everything else and the EVO is one of the best at that, GT-R not an option because they don't offer any value for money.
So rather than get into a vs debate, I would like to know what its like going from a 300rwkw rwd to a 250awkw EVO? From people who have made the switch.. cheers R
https://www.sau.com.au/forums/topic/445446-from-a-290rwkw-r34gtt-to-an-evo-7-9/
Evo would chew the 34 up for breakfast. Be aware that the real strength of the Evo is carrying corner speed so you have to be a committed driver. A 200awkW Evo driven correctly would in most circumstances walk away from a 300rwkW Skyline, making more ground on the corners than it's losing on the straights. 250kW would basically lose less ground coming off corners and down the straights.
Whether it's going to feel as exciting on the street would depend on how it's driven and how long you intend to keep your licence.
  • Like 1
yeah Aaron was as fast as my 300kw 33 around Sandown in his stock evo 7..was a slow day and we're both pretty shitty drivers I guess but just gives you an idea of the evos potential...Personally I still like the skyline better...the evo has the ability, but lacks the class of the Skyline..
If something newer and 2 extra doors is what you're after though, it ticks the boxes
I drove a 210-220 kw Evo X (I know, not the same car) and it was like night and day. If you want to drive on the street enthusiastically, you're going to have a great time going around curvy roads in one.
You could also do it in a GTR, you're just going to need to give it more RPM.
Given your first post, I think you're going to enjoy an Evo far more. Find someone who has one and ask to ride shotgun and you'll know within about five seconds whether its your thing or not.
I owned an R34 GTT, then went to an Evo 7 with 200awkw, and now to an r34 GTR.
Evo shat all over the GTT in Cornering, comfort, low to mid range power/torque. Evo felt allot quicker due to 21psi vs 13psi.
BUT, as someone who loves to drive, i got board with the Evo fairly quick. Just too clinical and seems to drive itself. The 4g63 motor doesn't sound as nice as an RB either
Evo to 34 GTR. Different story altogether.... GTR FTW
  • Like 1
As above really, the Skylines are good fun with 300+kw, evos are awesome too
You'll get bored at some point of whichever you have so if you've never had an evo or similar you should try it out
You're more likely to get done for a high speed infringement in the evo but maybe more likely to get done for sustained loss of traction or careless use with a skyline which about sums it up? :D
Edit: the sustained loss of traction is from traction issues, not trying to bake it as such :closedeyes:
Edited by WMDC35
I run my neighbors' EVO9 that has 240awkws in a straight line. My R33 had 380rwkws on vnt system, it pulled away in third gear after 140KM/H, that was with Mickey Thompson 275 ET tyres also.
So you pulled away, or the evo did? Quite interesting that this thread came up, as I have just sold my gts-t, and are now looking for some all paw fun. Big fan of the evo 6 shape.. Something about it. Just gets me jiggy!
Would love an evo 9 as the stock turbo is a weapon in itself on ethanol.. But the evo 6 shape is just too good. Too bad evo 9 turbo costs a pretty penny!
/\ quite often a decent skyline will eventually pass or pull away if it's a straight line & you reach a high enough speed, which usually doesn't happen on the road
Unless its godzilla.....if we're going to go all fast and furious on this..... the skyline GTR will outlaunch the mitsi evo every time. I don't know how many times i watched my wife dispatch evo's to the 60ft. But GTS-t a different story.
^ might also snap the output shaft, chew up a transfer case too if you're a rough driver
my friend thought it could light up all 4s in front of my house, clutch dumped it at 7k.. wasn't pretty LOL
You can treat a Skyline (minus R32 GTS-t) like a dirty hooker and it will take the abuse - you do that to a princess EVO and it will have a mental breakdown and PMS for weeks..
However EVO > Skyline in terms of performance, handling, comfort, doors, room for sex
I pulled away.
on the same time it was with a special turbo that built 23psi at 3500rpm.
Thought so, just wanted clarification that the extra 140kw actually did something ;)
If there is a large enough gap in horsepower/torque, then yes. Otherwise if it's basically neck and neck respectively, it's usually the other way around due to the Evo having less weight off the line, by the time the weight is a non-issue, the Skyline (or whatever other car) will simply keep accelerating at the same speed as the Evo, albeit a few car lengths behind. I understand that the 4 banger is making less power down low, but the revs are not likely to drop below 5k rpm, or even 6 depending on how it's set up. But you're right, this doesn't usually happen on the road :D
Same goes for tough Supra's that race litre bikes (as per youtube), they lose a few lengths on the jump, but after that it's basically the same rates of acceleration.
Dependant on power level, of course. Stock for stock, completely agree with you. 400awkw? Hmmm. Evo's in the states lay down some pretty skinny 60ft times.
A 380kw skyline can potentially do a 10 second quarter..
I doubt a 240kw evo can do that...
I doubt a 240kw skyline could either :P:D
Hahaha! Youtube search "evo blows tranny", some pretty hilarious results.
Sheptrans (I think) have transfer case/diff/gear box strengthening options for the Evo crowd in the states. At a minimum, I'd like to imagine that all Evo owners who 'drive' their cars are wise enough to realise this is the first big weak link. To have a bulletproof transfer case isn't *that* costly in the long run, same goes for the diff. Google search "golden ratio evo box" will give you the company that makes a tough gearbox for what really amounts to loose change.
Some good insight in this, I likey.
Not really fair to compare a 380rwkw GTsT to a 240awkw EVO ay, how about a 240rwkw GTsT vs a 380awkw EVO - that would be a total rape.. LOL.. You would expect a 380kw r33 to pull away from the 240kw evo though, otherwise it would be pretty embarassing with all that power - I'm pretty surprised the EVO managed to keep up till 140km/h. Meaning on road/ street speeds its almost unbeatable
Edited by rondofj
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
