G'day..I'm thinking of making a switch from a 290rwkw R34GTT to an EVO 7-9 when the right one comes up at the right price and right time...we will see....Currently running a Precision 5558 on 98 petrol and intending to run the EVO on 98 as a purely street daily car with 1-2 track days a year.
Question is -will a 250awkw EVO feel more crazy on the street and give much more excitement coming from a 290rwkw rwd r34??
250kw because that seems to be the EVOs sweet spot with mild mods and probably 300awkw with E85. I'm not a fan of going sideways, wheelspinning/ going nowhere and looking like an ass - I rather something that hooks up and is gone before everything else and the EVO is one of the best at that, GT-R not an option because they don't offer any value for money.
So rather than get into a vs debate, I would like to know what its like going from a 300rwkw rwd to a 250awkw EVO? From people who have made the switch.. cheers R
https://www.sau.com.au/forums/topic/445446-from-a-290rwkw-r34gtt-to-an-evo-7-9/
Evo would chew the 34 up for breakfast. Be aware that the real strength of the Evo is carrying corner speed so you have to be a committed driver. A 200awkW Evo driven correctly would in most circumstances walk away from a 300rwkW Skyline, making more ground on the corners than it's losing on the straights. 250kW would basically lose less ground coming off corners and down the straights.
Whether it's going to feel as exciting on the street would depend on how it's driven and how long you intend to keep your licence.
  • Like 1
yeah Aaron was as fast as my 300kw 33 around Sandown in his stock evo 7..was a slow day and we're both pretty shitty drivers I guess but just gives you an idea of the evos potential...Personally I still like the skyline better...the evo has the ability, but lacks the class of the Skyline..
If something newer and 2 extra doors is what you're after though, it ticks the boxes
I drove a 210-220 kw Evo X (I know, not the same car) and it was like night and day. If you want to drive on the street enthusiastically, you're going to have a great time going around curvy roads in one.
You could also do it in a GTR, you're just going to need to give it more RPM.
Given your first post, I think you're going to enjoy an Evo far more. Find someone who has one and ask to ride shotgun and you'll know within about five seconds whether its your thing or not.
I owned an R34 GTT, then went to an Evo 7 with 200awkw, and now to an r34 GTR.
Evo shat all over the GTT in Cornering, comfort, low to mid range power/torque. Evo felt allot quicker due to 21psi vs 13psi.
BUT, as someone who loves to drive, i got board with the Evo fairly quick. Just too clinical and seems to drive itself. The 4g63 motor doesn't sound as nice as an RB either
Evo to 34 GTR. Different story altogether.... GTR FTW
  • Like 1
As above really, the Skylines are good fun with 300+kw, evos are awesome too
You'll get bored at some point of whichever you have so if you've never had an evo or similar you should try it out
You're more likely to get done for a high speed infringement in the evo but maybe more likely to get done for sustained loss of traction or careless use with a skyline which about sums it up? :D
Edit: the sustained loss of traction is from traction issues, not trying to bake it as such :closedeyes:
Edited by WMDC35
I run my neighbors' EVO9 that has 240awkws in a straight line. My R33 had 380rwkws on vnt system, it pulled away in third gear after 140KM/H, that was with Mickey Thompson 275 ET tyres also.
So you pulled away, or the evo did? Quite interesting that this thread came up, as I have just sold my gts-t, and are now looking for some all paw fun. Big fan of the evo 6 shape.. Something about it. Just gets me jiggy!
Would love an evo 9 as the stock turbo is a weapon in itself on ethanol.. But the evo 6 shape is just too good. Too bad evo 9 turbo costs a pretty penny!
/\ quite often a decent skyline will eventually pass or pull away if it's a straight line & you reach a high enough speed, which usually doesn't happen on the road
Unless its godzilla.....if we're going to go all fast and furious on this..... the skyline GTR will outlaunch the mitsi evo every time. I don't know how many times i watched my wife dispatch evo's to the 60ft. But GTS-t a different story.
^ might also snap the output shaft, chew up a transfer case too if you're a rough driver
my friend thought it could light up all 4s in front of my house, clutch dumped it at 7k.. wasn't pretty LOL
You can treat a Skyline (minus R32 GTS-t) like a dirty hooker and it will take the abuse - you do that to a princess EVO and it will have a mental breakdown and PMS for weeks..
However EVO > Skyline in terms of performance, handling, comfort, doors, room for sex
I pulled away.
on the same time it was with a special turbo that built 23psi at 3500rpm.
Thought so, just wanted clarification that the extra 140kw actually did something ;)
If there is a large enough gap in horsepower/torque, then yes. Otherwise if it's basically neck and neck respectively, it's usually the other way around due to the Evo having less weight off the line, by the time the weight is a non-issue, the Skyline (or whatever other car) will simply keep accelerating at the same speed as the Evo, albeit a few car lengths behind. I understand that the 4 banger is making less power down low, but the revs are not likely to drop below 5k rpm, or even 6 depending on how it's set up. But you're right, this doesn't usually happen on the road :D
Same goes for tough Supra's that race litre bikes (as per youtube), they lose a few lengths on the jump, but after that it's basically the same rates of acceleration.
Dependant on power level, of course. Stock for stock, completely agree with you. 400awkw? Hmmm. Evo's in the states lay down some pretty skinny 60ft times.
A 380kw skyline can potentially do a 10 second quarter..
I doubt a 240kw evo can do that...
I doubt a 240kw skyline could either :P:D
Hahaha! Youtube search "evo blows tranny", some pretty hilarious results.
Sheptrans (I think) have transfer case/diff/gear box strengthening options for the Evo crowd in the states. At a minimum, I'd like to imagine that all Evo owners who 'drive' their cars are wise enough to realise this is the first big weak link. To have a bulletproof transfer case isn't *that* costly in the long run, same goes for the diff. Google search "golden ratio evo box" will give you the company that makes a tough gearbox for what really amounts to loose change.
Some good insight in this, I likey.
Not really fair to compare a 380rwkw GTsT to a 240awkw EVO ay, how about a 240rwkw GTsT vs a 380awkw EVO - that would be a total rape.. LOL.. You would expect a 380kw r33 to pull away from the 240kw evo though, otherwise it would be pretty embarassing with all that power - I'm pretty surprised the EVO managed to keep up till 140km/h. Meaning on road/ street speeds its almost unbeatable
Edited by rondofj
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
