Which ever style of these cars you prefer are both good choices. If you haven't had an evo or similar before you should try one out.
You'll find that the evo is quick around town etc but there's a lot of very quick evos & gtrs that are quicker
Breasts is an easier choice for sure!
Seems like it's been on your mind a while?
http://www.skylinesaustralia.com/forums/topic/365045-r34gtt-vs-evo78/
Give one a go, or wind the 34 up to 350ish ;)
My 2c. I have both cars and prefer the skyline.
The evo with less power is a few seconds faster than my skyline around a track.
The evo has superior response and acceleration, but the feel (steering/chassis) isn't as good as the skyline (I'd say less honest with all the electrics).
I find the skyline more enjoyable on the street (love engine/exhaust noise, better interior, slowish/deliberate long throw gearshifts, non-stiff suspension).
The skyline requires more effort to punt around a track quickly and I appreciate that aspect, along with watching better drivers drive rwd skylines quickly!
I noticed the factory diff always spin one wheel much harder then the other on take off just like in the clip. Happens to mine as well, Its alright once in third. Rolling start might give the skyline a better chance of winning.
Yes you can go past GTRs because GTSTs and Evos are easier and cheaper to work on . If you are rich and pay people to work on them GTRs are fine , they lack cubes for their mass buts that's life .
Better feel and balance in a GTST/GTt than an Evo in good nic , no way in hell . Far more feel in an Evo 6 GSR steering handling braking wise that a GTS25T , I have both and they both have Pilot Sport Rubber (PS3 Evo) (PS2/PSS R33) . Both have light 17x8.5 wheels , the 33 has the full SK Bilstein kit and the 6 has Whiteline bars and Evo 9 rear Bilstein struts .
Evos are closer to GTRs than GTST/GTT package wise with less comfort and excluding outright power/speed probably better than a GTR in the twisties . Driven wheels grip better than "idlers" and Skylines have a large portion of their engine out past the front wheels . Aside from the lack of FrWd that's why M3s tended to be better handling straight six performance cars than Skylines . Look how far back the engine is in relation to the front wheels , and how much closer to 50/50 weight distribution they have front to rear .
GTR isn't as bad as the original Audi Quatros were but they were both the result of fitting 4WD into an originally RWD or FrWd platform .
Evos are pretty much the same as Lancers back to the front doors except the floor pan from that point is totally different . Ralliart designed that not MHI , up to E6 anyway , so they had lots of freedoms with rear driveline suspension brakes wheels etc .
The thing to remember is that Evo was designed to be a Tarmac Rally basis where Skylines were open road touring cars - GT . It takes something special to be agile and sharp on slippery constantly changing surfaces and they live to be thrown around with everything spinning ALL the time . I was in my mid 20s when GMS raced R32s in Grp A and I don't remember seeing them spinning all 4 most of the time . I do remember them looking smaller and more nimble than the V8 powered taxis and Sierras were really the only serious opposition . Also it wasn't always wet and slicks are the gun thing in the dry .
If you had the same tyres and tarmac suspension , and the same power with equal top speed gearing a GTR probably isn't any better than an Evo , possibly on a fast circuit because of its extra capacity but on one with hairpins and S bends my monies on the Evo .
IMO for dedicated drag race a tubbed RWD is the go .
A RWD Skyline if you punch it everywhere would better suit the "skid/drift brigade" than an Evo because at the same speeds the Evo does more easily and neatly . I guess it's this trying to find limits that some people like . They are higher in Evo and GTR which means going faster to find them - way way faster than speed limits allow and I say again when you lose it at that kind of pace the crashes are often monumental .
You often hear people say AWD cars like Evos are so easy to drive that they make a mug look good . The reality is they get out of shape at higher cornering speeds and when they do they are harder to recover so no the technology doesn't automatically save a goose from themselves .
A .
  • Like 1
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
