It is a S15 Silvia with RB25DET and R33 gearbox. 8kg fr 6 kg r on softest setting. It has camber and toe arms and it doesn't have much camber.
It holds up if I floor it from a rolling start on a motorway in 2nd, but it will lose traction on back roads or where tarmac is not as good
decent setup then.
im surprised those tyres don't hook up better...
I used to have those coilovers in that spec and I found that running the rears at about 10-25% damping was the best. Something about fully soft wasn't goood and I remember the traction not being as good. THat was in an R33 though and only 240rwkw...
Edited by jjman
Mick, yes the supra will, but then the thrill being its a different car and right up there at the performance forefront, not to mention the easy power u can get outa them and the GT feel, cockpit etc, a monster that actually looks nice /sporty
Kasko I was lucky, checked ebay and a set came up at one of the skyline wreckers-think I got away with $450- a steal.. Just test the dampers by removing tops, compressing by hand and checking rebound. And f$&k those coilovers off..
Yep dunno if the SK Bilstein Whiteline kits are still around , I think he said some of the springs may not be available .
However , the SK re rated Bilsteins are and that is a good start . He said you can do a coil over conversion on them (threaded sleeves on circlips) and use small diameter springs in the right rate . Really all the bling lookin tops with spherical bearings do is give you grief on a Skyline .
Also he organised some years back an adjustable Silvia stut top that solves some of the lack of compression travel issues .
If genuinely interested I may be able to contact him , cheers A .
It's not hard to contact Gary. He responds to PMs on here. I bought a set of his tricked out dampers from him only a few months ago.
I did have some trouble with springs on an R32 GTSt. The normal low Kings springs seem to be all wrong, about 35mm too low, even when the Bilsteins' perches were set on the highest groove. So I ended up with GTR springs, which is not a problem at all, as they are a higher rate than the GTSt springs anyway - right in the middle of the happy range of about 5 kg/mm.
You can of course get Eibach springs, and the coilover conversion (which costs a fair bit of money) is of course still an option.
When I bought mine originally, I had the same issue.
On the "std" (middle) setting, the whiteline lowered springs were about 30mm too low. Even on the highest circlip groove, the car still sat too low (10-15mm from memory). I ended up having more grooves machined into the shock (as recommended by SK). Car now (at its highest setting) sitts about 355mm eyebrow height on all corners but drivers front. Drivers front sits at 350mm.
Contemplating chucking stock springs back onto the bilsteins and running them at std height...
Edited by R32Abuser
That was with Whiteline springs? Gary has recently said to me that he'd not heard of anyone else having this problem with either type of spring. The Kings springs are supposed to be copied from the original Whiteline design (according to Gary, who designed the Whiteline spring). I had wondered if Kings had started stuffing up the specs on the R32 springs, but maybe there has been a problem of bigger proportions.
I have previously driven a well set up soarer in anger and loved the setup, bilsteins and 'stock height' King Springs.
Just a thought.
True to his name this thread is on track as a trip to whitecastle.
Yup...with the whiteline springs that came in the kit.
IIRC I had a PM from gary where he explained words to the effect of..."On the std (yellow) cir clip groove, std springs will sit at OEM height (~360mm eyebrow height or there a bouts)."
The whiteline springs being the lowered type (~25mm lower than std), would make the car sit 25mm lower than OEM height on the std cir clip groove.
Hence, you would need to have a cir clip machined 25mm offset to the std. All of this is not taking into account any spring sag...
Edited by R32Abuser
Nah that can't be right. That ~350mm height is the best lowered height. The standard height is somewhat higher than that. Something like ~370mm.
Cant remember what the OEM eyebrow height is, but I know to pass regency its 360mm. 370 probably is about right now that I think about it!
Last time I asked Gary he said the Evo spec Bilsteins from some 8s and 9s are pretty good valving wise . A certain 7 is doing well with them though you do get side load problems if you use concentric lower spring seats on the front ones - which would include pretty coilovers .
A .
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
