It is a S15 Silvia with RB25DET and R33 gearbox. 8kg fr 6 kg r on softest setting. It has camber and toe arms and it doesn't have much camber.
It holds up if I floor it from a rolling start on a motorway in 2nd, but it will lose traction on back roads or where tarmac is not as good
decent setup then.
im surprised those tyres don't hook up better...
I used to have those coilovers in that spec and I found that running the rears at about 10-25% damping was the best. Something about fully soft wasn't goood and I remember the traction not being as good. THat was in an R33 though and only 240rwkw...
Edited by jjman
Mick, yes the supra will, but then the thrill being its a different car and right up there at the performance forefront, not to mention the easy power u can get outa them and the GT feel, cockpit etc, a monster that actually looks nice /sporty
Kasko I was lucky, checked ebay and a set came up at one of the skyline wreckers-think I got away with $450- a steal.. Just test the dampers by removing tops, compressing by hand and checking rebound. And f$&k those coilovers off..
Yep dunno if the SK Bilstein Whiteline kits are still around , I think he said some of the springs may not be available .
However , the SK re rated Bilsteins are and that is a good start . He said you can do a coil over conversion on them (threaded sleeves on circlips) and use small diameter springs in the right rate . Really all the bling lookin tops with spherical bearings do is give you grief on a Skyline .
Also he organised some years back an adjustable Silvia stut top that solves some of the lack of compression travel issues .
If genuinely interested I may be able to contact him , cheers A .
It's not hard to contact Gary. He responds to PMs on here. I bought a set of his tricked out dampers from him only a few months ago.
I did have some trouble with springs on an R32 GTSt. The normal low Kings springs seem to be all wrong, about 35mm too low, even when the Bilsteins' perches were set on the highest groove. So I ended up with GTR springs, which is not a problem at all, as they are a higher rate than the GTSt springs anyway - right in the middle of the happy range of about 5 kg/mm.
You can of course get Eibach springs, and the coilover conversion (which costs a fair bit of money) is of course still an option.
When I bought mine originally, I had the same issue.
On the "std" (middle) setting, the whiteline lowered springs were about 30mm too low. Even on the highest circlip groove, the car still sat too low (10-15mm from memory). I ended up having more grooves machined into the shock (as recommended by SK). Car now (at its highest setting) sitts about 355mm eyebrow height on all corners but drivers front. Drivers front sits at 350mm.
Contemplating chucking stock springs back onto the bilsteins and running them at std height...
Edited by R32Abuser
That was with Whiteline springs? Gary has recently said to me that he'd not heard of anyone else having this problem with either type of spring. The Kings springs are supposed to be copied from the original Whiteline design (according to Gary, who designed the Whiteline spring). I had wondered if Kings had started stuffing up the specs on the R32 springs, but maybe there has been a problem of bigger proportions.
I have previously driven a well set up soarer in anger and loved the setup, bilsteins and 'stock height' King Springs.
Just a thought.
True to his name this thread is on track as a trip to whitecastle.
Yup...with the whiteline springs that came in the kit.
IIRC I had a PM from gary where he explained words to the effect of..."On the std (yellow) cir clip groove, std springs will sit at OEM height (~360mm eyebrow height or there a bouts)."
The whiteline springs being the lowered type (~25mm lower than std), would make the car sit 25mm lower than OEM height on the std cir clip groove.
Hence, you would need to have a cir clip machined 25mm offset to the std. All of this is not taking into account any spring sag...
Edited by R32Abuser
Nah that can't be right. That ~350mm height is the best lowered height. The standard height is somewhat higher than that. Something like ~370mm.
Cant remember what the OEM eyebrow height is, but I know to pass regency its 360mm. 370 probably is about right now that I think about it!
Last time I asked Gary he said the Evo spec Bilsteins from some 8s and 9s are pretty good valving wise . A certain 7 is doing well with them though you do get side load problems if you use concentric lower spring seats on the front ones - which would include pretty coilovers .
A .
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
