Hi,
Just wondering when the standard turbo spools up. I havn't actually looked at the turbo to make sure it is standard but i guess it would be.
Anyway it spools up at about 3500-4000rpms. I thought it would be a bit earlier.
Is there anyway to advance the spool up?
I installed a FMIC yesterday and it didn't make heaps of difference. It made it feel more punchier, as in, it hits full boost at once rather than building up.
anyway there seems to be a pretty big flat spot in 2nd when i hit 75km -90km and then 90-100 is good. I heard that resetting the ecu every so often can improve these problems but not sure as I havn't done it yet.
I think a powerfc is next on the agenda.
JaFF
https://www.sau.com.au/forums/topic/44549-slow-spool-up/
R33? Flatspot? Running too much boost.
Stick around 10-11psi.
3500-4000rpm for a R33 stock turbo is way to high.
Thats around the territority of the ol' RB20 running 1 bar or so. (Depending on driving conditions)
I have a R33 S2 and it spools between 3500 and 4500 running standard psi...goes like a dream for me...advan is puttin it up to 10psi for me in couple of weeks and throw it on the dyno and see wats goin on...but i dont see a prob with mine
https://www.sau.com.au/forums/topic/44549-slow-spool-up/#findComment-910391
it goes well. just a lil flat in spots. mainly in second gear- higher revs.
I have a boost controller which is set to 10psi but dont use it daily.
now i have the fmic i probably could run at 10psi. Might try later. Just have no where to test the car properly. 70km speed limits all the way from work to home :D
Was just interested to see whn it should spool up.
JaFF
https://www.sau.com.au/forums/topic/44549-slow-spool-up/#findComment-910399
JaFF
ive got a stock intercooler and i hae no probs...i get low boost at over 3500rpm then the baby kicks at 4500rpm nicely ...il b interested to see wat happens wen advan puts the boost controller on at 10psi wen at stock boost it goes this well all ready...just pick a straight quite road at night and test it like i did lastnight u can really see how well it runs in the cool air of the night ...im way impressed
https://www.sau.com.au/forums/topic/44549-slow-spool-up/#findComment-910405
uhh, i probably mean hitting boost like 7psi at 3500
I spose it kinda builds up b4 then. havn't taken much notice. since the fmic it seems to hit all of a sudden at 3500. gives that sinking feeling. I just thought it should come on full boost earlier.
still i think i want to get an electronic boost controller (only have turbosmart single stage atm), i've heard they handle things a bit better.
https://www.sau.com.au/forums/topic/44549-slow-spool-up/#findComment-910743
Hey Jaff.
I had a similar problem on my R32 when my ehaust manifold gasket blew out. the turbo just seemed to take longer time/higher revs to start pumping out decent gas. in case you're curious my car made a horrible noise coming from the manifold on startup, sounded like a tractor? weird. give it go before you shell out big bucks. good luck.
https://www.sau.com.au/forums/topic/44549-slow-spool-up/#findComment-911163
meh to rb20det all round..
JaFF: sounds perfectly normal.. One way you can reduce the spool up is to add an exhaust camgear (i noticed a fair change with this in), get cooler air in (shield pod, or air feed it), reduce rotational mass (flywheels, etc), also try reducing the backpressure of your exhaust system will probably help.. maybe a dump pipe or get it heat wrapped. Electronic Boost control also helped mine spool up a tiny bit quicker (or at least smoother).
I think the smoother and faster the engine revs to a certain point, the quicker the turbo will spool. There is probably proper physics there somewhere which somebody can explain.
https://www.sau.com.au/forums/topic/44549-slow-spool-up/#findComment-912107
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 😂 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
    • Porous blocks are a known issue on something like a Porsche M96, it's not really something I've ever heard of on an RB26. It's possible what people thought was a "porous block" was really a cracked block that they just didn't spot the crack on.
    • This is a controversial subject really, the whole power vs fun thing I mean And this is the main reason I got back into a MX5 Of the last few notable daily cars I've owned whilst I have frequented SAU R33 GTS-t: fun, but because I'm a idiot I modified well past a reliable fun car and ended up hating it, although that was my fault because I tried to have a daily cruiser and race car all in one, the family called it the sometimes car, because sometimes it was working, sometimes it was broken, gladly sold it NB MX5: brilliant car, thrashed the Bejebus out of it, but, again, was stupid and deleted the air con, power steering and stripped the interior out, whilst still fun, and reliable, and super cheap on consumables, it was not a fun place to be going on long cruises, I did love it, but basically every family member hated going anywhere in it, sadly sold it 2015 WRX STI: soulless thing that looked like your average Kia sedan and had that horrible boxer engine with glass ringlands, the family did like it though, that thing was one of my stupidest purchases and I still regret it 2017 Toyota 86: 😪 if I didn't crash it, I would probably still have it, it was a fun little thing, even with that horrible boxer engine, the family did like it, the only reason I didn't get another 86, or, BRZ was the boxer engine, I should have learnt after owning the STI, but I'm a idiot VX SS: great cruiser, fits the whole family, and was fast as.....in a straight line, but a big fat thing, so no enjoyment throwing it around corners, the family was unimpressed with the whole boganness of if, but they did admit it was a comfy place to sit on long cruises As for the NC, I feel it is perfect for what I want, or need out of of a car, whether I'm cruising the Hwy, back roads, twisties or peak hour traffic, the Mrs doesn't mind driving it either, or cruising in it as well, although she does bump her head of the roof nearly every time she gets in, which is farking hilarious, and the kids love taking it for a thrash as well So basically, I've had constantly more fun, and way less headache and heartache, both on the track and on the street, in low powered cars,  go figure.....LOL One thing though, the Mrs has stated that the cams have made the exhaust sound much louder, which they have, but it doesn't bother me, in fact, I actually like it, but, to negate any future comments from the Minister for War and Finances I may look at some changes to the rear muffler set-up to drop the volume down a tad to appease her when we are out and about in it
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
