Faawks Posted July 11, 2014 Share Posted July 11, 2014 Just as the title says, I'm about to do a thermo fan conversion on my R33 as my fan it about to break. I want to avoid using those adjustable temp switches. What temperature range should I aim for with the temperature switch? It's an rb25det running at 12psi. Also, where would the best place be for the position of the switch? Cheers. Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/ Share on other sites More sharing options...
jay-rod Posted July 11, 2014 Share Posted July 11, 2014 Dont. Get a new clutch fan. 1 Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7336451 Share on other sites More sharing options...
Daleo Posted July 11, 2014 Share Posted July 11, 2014 Dont. Get a new clutch fan. This x 11ty. Read this, then go buy a new clutch. http://www.aaroncake.net/rx-7/efanmyth.htm Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7336454 Share on other sites More sharing options...
Faawks Posted July 11, 2014 Author Share Posted July 11, 2014 Thanks guys. It's there a way to stop the clutch fans from breaking every 6 months or so? My mate put a new one in his car and it's already got 2 large cracks in it after a little over a month. Maybe another brand? I admit that both mine and his cars get thrashed, but that's pretty much what we own them for... Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7336640 Share on other sites More sharing options...
89CAL Posted July 11, 2014 Share Posted July 11, 2014 I've had a new one for over a year and it's fine? Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7336644 Share on other sites More sharing options...
jay-rod Posted July 11, 2014 Share Posted July 11, 2014 I would say possibly engine mounts crapped causing the engine to move and the fan is hitting. That or its getting to hot. If you buy a geniune one it will last another 15 years or so. Second hand....thats a gamble really. Dont by gtech...... Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7336679 Share on other sites More sharing options...
Daleo Posted July 11, 2014 Share Posted July 11, 2014 Dont by gtech...... Best advice ever. Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7336702 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 11, 2014 Share Posted July 11, 2014 Hrms I track my car with the stock clutch fan, I don't see it breaking? Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7336731 Share on other sites More sharing options...
Faawks Posted July 11, 2014 Author Share Posted July 11, 2014 I don't think it's hitting, mine has 2 cracks between every blade, I'm just getting in early. My mates actually flew apart while he was drifting, made a complete mess of everything. His new one already has 2 large cracks but I don't know if it's genuine or not. Stay away from gtech, check. Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7336756 Share on other sites More sharing options...
89CAL Posted July 11, 2014 Share Posted July 11, 2014 Mine had cracks appearing between the blades that's why I replaced it with a new genuine one. Has been fine Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7336759 Share on other sites More sharing options...
Faawks Posted July 11, 2014 Author Share Posted July 11, 2014 Ok cool, I'll get on that asap. Cheers Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7336895 Share on other sites More sharing options...
iruvyouskyrine Posted July 12, 2014 Share Posted July 12, 2014 While I agree/understand the advantages and disadvantages of thermo fans a lot of drifters do use them, myself included. I have never seen a stock fan break but I don't like the idea of using a stock one with cracks and continuously revving it over 5000rpm. I know that I could buy another but I just like the advantage of thermo fans, it really comes into it's own when you have a nice setup with twin fans and a cross flow radiator. With drifting (depending on the track) you can sit in a staging area for maybe 2-3 minutes at a time. After flogging the shit out of your car the twin fans really cool it down well. Not saying a stock fan couldn't but thermo fans DO work. I have only ever seen ONE(!) Drift car with a JZ engine running a stock fan, and I'd say over 50% of RB's run thermo fans as well. These are just my experiences so take it with a grain of salt, but for people who say they don't work/are crap etc then they are incorrect Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7337422 Share on other sites More sharing options...
jay-rod Posted July 13, 2014 Share Posted July 13, 2014 (edited) Never said they dont work, you need to go high end fans/brand to get the most out of themThen u need to take in to account the power draw.And if it actually is going to hinder airflow at higher speeds ( ie bad shroud) He should be getting a bigger 40+ mm radiator instead if he hasnt already.I track my car with stock fan and 50mm radiator and idles fine after a good heavy 4-5 laps Edited July 13, 2014 by jay-rod Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7337795 Share on other sites More sharing options...
Faawks Posted July 18, 2014 Author Share Posted July 18, 2014 Yeah I'll be looking into a better radiator, I've already purchased a new fan Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7343820 Share on other sites More sharing options...
blind_elk Posted July 20, 2014 Share Posted July 20, 2014 I gave up on the thermo I ran in my GTS4 (admittedly without any shroud). Could not keep the engine cool - the slightest incline (at highway speed) caused the thermo to switch on. After I put the standard fan back on, have had absolutely no problem with temperature control. Figured the couple of kW I gain running the thermo wasn't worth the cost of an engine rebuild. Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7344832 Share on other sites More sharing options...
jay-rod Posted July 20, 2014 Share Posted July 20, 2014 You wouldnt gain kW with the thermo As it draws more amps, ur alternator would be working harder, therefore mitigating any plus. Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7344985 Share on other sites More sharing options...
blind_elk Posted July 21, 2014 Share Posted July 21, 2014 Jared, I don't think you understand how a thermo fan is designed to work. You will gain a few kW if you set the thermo up the way it was intended, ie to only be working when the engine temperature gets too high. Alternator only works harder if the thermo fan is on. The majority of the time the thermo isn't on. Only comes on when the engine temp reaches a pre-set thermostatted temperature. Therefore I gain a couple of kW because the engine doesn't need to drive the clutch style (factory) fan. Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7345708 Share on other sites More sharing options...
White GTS-T Posted July 21, 2014 Share Posted July 21, 2014 Which is exactly how the viscous hub works. It only locks up when the viscous fluid is hot. Once locked and after the airflow across the hub has cooled the fluid, it disengages and freewheels again. The effect of the 'drag' on the motor, when the hub is freewheeling, would be negligible at best 1 Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7345743 Share on other sites More sharing options...
iruvyouskyrine Posted July 21, 2014 Share Posted July 21, 2014 The above is correct, if the viscous hub works properly which in my experience is not very often on most skylines nowdays. Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7345792 Share on other sites More sharing options...
89CAL Posted July 21, 2014 Share Posted July 21, 2014 If your changing to thermo fans to gain horsepower, your a long way from being on the right track If your stock setup works then leave it alone. If you are doing a thermo fan conversion for a practical reason then go for that. I really don't understand people who go on about the horsepower gains from running thermo fans. Link to comment https://www.sau.com.au/forums/topic/445510-thermo-fans-conversion-temperature-range/#findComment-7345838 Share on other sites More sharing options...
