Hi, I'm looking to purchase an exhaust for my gtt. I've come across the hks high power and silent along with the blitz nur spec r. Does anyone know what exhaust is better sound wise and performance wise? Also do I need any sort of permit for this mod ?
And if I open my boost controller so it'll be at 0 bar and have a control valve after the cat will my exhaust be under 90db?
Will greatly appreciate any help :)
https://www.sau.com.au/forums/topic/445516-exhaust-help/
Step 1) Find good local exhaust shop.
Step 2) Engage good local exhaust shop to build you a 3 - 3.5" exhaust with large rear and mid mufflers and large 100 - 200 cell 5" Venom cat or similar.
Step 3) Drive away with knowledge that Steps 1 & 2 have just cost you less than buying Jap exhaust whilst flowing more and probably being just as quiet if not a little quieter.
I do not understand your question about "opening boost controller so it'll be at 0 bar", nor do I understand why you would want a control valve after the cat. Neither of these things make sense, although the latter might be interpreted to be a reference to a dumb arse method of shutting up an exhaust that is too loud.
  • Like 1
https://www.sau.com.au/forums/topic/445516-exhaust-help/#findComment-7336381
My system is simply a 3 1/2inch jap system cat back, cost $200 from wrecker then I replaced muffler with a 3inch Xforce and a
100cell cat, so probably all up $700, seemed to flow well enough, stainless too so cheaper than getting it all made up,
ive had the nur spec 4inch muffler which is basically a massive loud cannon piece of crap, and the jap muffler
HKS etc is basically a
restricted crappy cannon that looks fully sick and sounds hektic, so that counts for something lol...
Edited by AngryRB
https://www.sau.com.au/forums/topic/445516-exhaust-help/#findComment-7337521
Aren't you affiliated with them? If so you should really point it out when recommending something.
He sure is, should also be paying to advertise his products all the time.
I'm all for his products but there are people who are following the rules and paying to advertise products on here
https://www.sau.com.au/forums/topic/445516-exhaust-help/#findComment-7337561
Which ones did you buy in the end? I have been interested in a HKS hi power silent. Its only a few hundred more than a mild steel custom exhaust.
However, judging from hundreds of opinions, the HKS "silent" exhaust ranges from "can't hear it" to "sets off car alarms at idle". For that reason I haven't been willing to risk the coin on it.
https://www.sau.com.au/forums/topic/445516-exhaust-help/#findComment-7337697
I bought the hks hi power silent second hand from japan. I've also seen thst myself when looking up info about it. When it gets shipped to Perth and installed which won't be for another 8 weeks minimum I'll hook it up to my car and test it properly and upload a video and post the results. Only ones you see on YouTube they barley get the car over 4000 rpm so you can't tell if it's good or not :/
https://www.sau.com.au/forums/topic/445516-exhaust-help/#findComment-7339032
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
    • I don't know what globes/headlight connector they run, but I'd be looking for a female adapter to plug into the existing headlight on one side. Something like this https://www.ebay.com.au/itm/256017245989 Then I'd use a pair of single input, double output relays (one for low, one for high), mount them in a spare space in the fuse box if you want to to look more original (and be easier to maintain). Then 2 new power sources from the main stud in the fuse box via a fuse to each relay. Low from the headlight adapter pin triggers low relay and high from the high headlight adapter pin triggers high and low. Earth the relays and new headlight sockets and off you go. Because it triggers off the original headlight all of the dipping/hi on/high flash all still works
    • I reached 10 posts and wanted to make my build thread too but still can't add pictures to posts so I have no idea how it works 😂
