Hi Everyone, attempt 2 at posting this thread.
Tip: Don’t be trawling Wasteland threads and post something right before alt-tabbing back and trying to post a for sale thread that’s massive.
TLDR: Buy the engine that did this, thanks. Rest of complete setup for sale if you or someone does. Can just bolt it into a R33 or R34 GTT and save moneys (like, everything). Obviously could put the engine anywhere you can put a RB25. Very negotiable if you want to buy the entire thing and bolt it or re-sell it or what have you.
https://www.facebook.com/ChequeredTuning/posts/718855688158365
I recently ‘finished’ my R34 setup, finally, after about 6 years of crap.
Then I drove it into an Embankment at low speed and bent the chassis and pretty much nothing else, so everything in this list is 100% working and very near new. However, it was enough to write off the chassis.
I will only separate parts if the engine is sold. If the engine is not sold, I’ll get the lot put back into a different shell. In this way I’m letting rajab decide whether I go GTT or something else.
Note: In car and running, can physically show you if in Victoria.
Engine:
BC 2.9L Stroker Kit http://www.briancrower.com/view.php?pn=BC0238
Tomei Type B Poncams
Tomei Exhaust Cam Gear
Nitto Custom Forged Pistons
Ported/Polished Head (unsure on exact flow. clearly works though, and can see the exhaust side is slightly larger than stock manifold ports)
Spitfire Coilpacks
JUN Oil Pump
New Gaskets, Bearings
when rebuilt
New Idler, Tensioner, Timing, Water Pump when rebuilt
Cometic 1.8mm Metal Head Gasket
ARP Head Studs
Xspurt 1400cc Ethanol Injectors
Turbosmart Kompact Plumb Back BOV
EARLS Fuel Filter
Totally legal in Vic. Totally legal anywhere else, too. Vicroads will give you no problems with this.
Engine has done 15,000kms since built.
As before, can see running.
Has been 1 day since dyno runs. Yes, I bent the chassis the day after. This was sad.
I have all the reciepts, emails back and forth, all the info you're likely to want, though really the proof is in the dyno sheet.
Seems to love timing (running a lot, no pinging)
Seems to love boost (running a lot, no pinging or weirdness)
It's about as solid as any engine you'll ever get built by someone who doesn't call themselves "Nissan"
It also won't take 6 months of stuffing around, waiting, waiting, waiting, waiting, waiting and so on to be built, put together, put in the car, run in, etc. It's all done. Put it in and drive.
If you buy the ECU and Turbo and everything else as its for sale, you won't even need a damn tune. Ever. lol
I'd love $12k for it. I'm negotiable. That seems like a high number. If you like, google the parts listed above and ask your local engine builder for a quote on labour. Then add the cost of waiting for it to all arrive, be put together and so on. It's OK. I'll wait. But I'm pretty negotiable if need be. But not stupidly so. 3k will not get you this engine and I'll just buy a stock auto GTT sedan for about $3 and get it all put in there and get back to 330RWKW at 3500 RPM.
Lets entertain the thought that someone buys the engine. If so, everything below this sentence is also for sale. it's also very new.
Haltech Platinum Sport 2000 (this is a glorious ECU)
Haltech Wideband CAN Controller (controls AFR on the fly, 200 times a second. Has stuff built in to stop it doing weird things and blowing your engine. You can also set it to max adjust like 1% if you're super worried). Not that you need it, because the tune in the ECU had this OFF when it got the AFR mentioned on the Chequred tuning link.
Full E-Flex sensor. Put whatever you want in the tank, man.
Garrett GTX3076R
Turbosmart Hypergate 45mm - This is welded onto the turbine housing. This setup clearly works. If you hate it, you could always put on a kando housing for $200 and mount this wherever you want with whatever manifold you want.
Walbro 460 LPH Fuel Pump - complete with super wiring!
Scotty Custom dump+screamer made by the venerable scotty nm35 - 2x45 degree stainless bends instead of the usual 90. Goes to 5in cat. So much flow! Has seperate 2in screamer which could be plumed back into the cat if you ask nicely. I was going to do this, but maaaay have found myself making this thread instead. Shit.
Suspension and Grip things
Front and Rear Bilstein Shocks
Eibach front and rear main springs.
Eibach rear helper springs
Coil over kit x4 so you can raise or lower the height and be fully sick if you so wish (I didn't)
Custom Front Strut Tops - Allows more travel in the front. Just incase joe cop decides to push down on your bonnet. Or say, you go over a bump.
Whiteline Caster Kit
Whiteline Front Camber kit
Whiteline Rear Camber Kits x 2
Bump Stop Kits X 2
R34 Series II Helical Diff and half shafts - Someone said these were rare. Works well!
Rear Subframe alignment kit (pineapples - they work!)
Whiteline 24mm Front Sway Bar (BNF24Z)
Whiteline 24mm Rear Sway Bar (BNR11XXZ)
Heavy Duty Swaybar Links for the above
Brand new Nitto NT05 Tyres - 245/40/18 and 275/40/18 on F/R respectively. Ok, they've done maybe 100kms.
Autech 8piston 356MM Front brake kit.
People talk bla bla bla about suspension all the time, but I was able to go WoT in 1st gear (auto, remember, 1st gear is a bit longer) with dyno results posted above and not lose grip. I would say its worth spending the money and not getting BC's and would do it again. Or you could save half the cost and buy mine. If you buy my engine. Which is again, saving a lot.
I also have a really, really, really built Auto transmission for aforementioned R34. I know you're reading, yawning, thinking "man, lolz, auto" but it has its own ECU, two transmission coolers, and is connected to the paddles on the R34 steering wheel. Touch the button, insta shift goodness. Touch the button when you're cruising around town, insta shift smoothness you can't feel. Do it at 7000RPM at WoT and you may or may not need spine surgery.
But considering you fell asleep reading that sentence about automatic transmissions, whatever, buy the engine. Or not.
May seem like a lot, cost a lot more to begin with. Be financially responsible by buying the fruits of my financial irresponsibility!
PM me, PM me now!
Edited by Kinkstaah
That's a terrible story Greg.
I for one am ready to take advantage of your misfortune should you get to the point of selling the various bits. I am interested in the diff and driveshafts (assuming you meant the driveshafts when you said halfshafts).
cheers
And the seagulls come to pick up the chips. :P
gearbok and tcm if you want to part. or just the tcm =D
Alvin, I already shotgunned the TCU. Get in line. ;) haha.
interested in;
Haltech Platinum Sport 2000 with long loom?
Possibly
I'm in melb so makes it easy.
That really really sucks Greg :/
(I think the 'easiest' option, if you can get over the heartbreak, would be to lift the gear into another chassis as you say... There's a GTT one going for <6K in the classifieds)
Anyway, someone buy this engine, glws.
Well it's good to know if I manage to sell the engine, the rest of the bits should sell in approximately 0.001 of a second.
I'd probably take less than 12 for the engine. When I say "engine" mean everything connected to the engine but not including the turbo and anything from that point onwards. I do realise that not many people just cart around that kind of money for an engine unless they were about to pull the trigger on their own build.
I have receipts for parts only inside that thing for considerably more than that. Given it'd cost $0 to assemble it, as it's already going tis technically a good deal, but at the same time, yeah, building any engine is an expensive venture.
If all else fails, I just need to see someone selling an auto R34 GT-FOUR and I'll just drop both cars off at Scottys place......
hey mate whats the prices on each item
Bump Stop Kits X 2
meh, they're not that expensive to buy new anyway, its the tuning part that's a bitch.
12k+ for a long motor seems a bit high dude.
There was a killer complete setup with rebult rb25 and rebuilt box for sale a few weeks ago on gumtree for 12,5k.
I get it costs big bucks to build these things, but based on a good 8+ months of looking before starting my build think you might have to drop that price to get a sale. After all that hard work, you might be better off buying a rolling shell and keeping it.
It wouldn't be the long motor, it'd be everything in the engine bay. Could literally bolt whatever you want, or use my working bits. The more people want, the cheaper it gets. I'd definitely be picking this one over a 25 for 12k.
And I'm negotiable, and I would ship it. I'm only concerned as I wouldn't like to have it get damaged while being shipped or something which would be rather bad for all parties (hence the 'can see it running!') thing.
I realise the price is high, and I don't mind murdering that price if someone actually makes an offer. Doesn't have to be here, send a PM. You may be surprised on just how much I can throw at people when it comes to convenience. Do some tire kicking. I can attest my PM box is full of people who want everything except the engine. Buy the wreck and you'll make the cost of the wreck back in frigging extra bits people want.
I'm quite aware that the number of people who are like "oh, I am about to forge an engine for a GTT or GTST or Stagea" is quite low. It just doesn't happen often. People seem to build RB26's which are arguably not as good as a Neo anyway.
Failing that, it'll go into a GTT or GT Four (if I can find one for sale...)
I don't mean to keep bumping my thread - Send a PM with a ridiculous offer and see what happens.
I have low expectations of selling it, but you never know ;)
Wow... That long motor would be a nice addition to my engine bay :woot: but bank account says :no:
Sorry mate, I don't have the original parts, original cams, pistons, crank etc, was living in an apartment with no garage when the engine got built, so I didn't keep those for storage reasons.
  • 2 months later...
Sorry for future searchers (thought I updated this)
None of this is available. I ended up getting it put into a new body.
  • Like 4
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
