Hi,
Just wondering if someone can tell me what the following electronic gizmo's do:
The smallish one that lives under the synthetic parcel shelf near the top of the the drivers side rear suspension in a R33 GTST?
The big one under the parcel shelf in the boot fitted to the under side of the steel parcel shelf drivers side R33 GTST?
Thanks
Mat
Small on in the back right corner near suspension refer to this:
- http://www.skylinesaustralia.com/forums/topic/430031-r33-help-what-is-this/#entry6964530
- http://www.skylinesaustralia.com/forums/topic/422135-what-is-this-electrical-item-under-parcel-shelf-in-r33-with-pics/
On further inspection, you already asked this 17 months ago :P
Unsure about the one undernearth though.
wow, shows how good my memory is/was. :wacko:
Leave them alone
car is unregoed track car with hicas locked out.
Figured that the larger one under the parcel shelf was hicas related??? but unsure of its function when removed?
as you remove it you'll loose extra power steering assist, it's there to detect lower speed and allow more assistance to the power steering rack and as you hit a certain road speed the assistance drops off leaving you with a more planted car
You basically lose all power steering. With no power to the solenoid it applies minimum effort which is probably about the same effort it applies at around 100kmh
I've had my HICAS ECU recently play up and it was horrible going around car parks etc with no power steering. Granted that isnt a big concern for a track car, but you will still still find its not as nice on slower speed corners
Geez way to make things complicated Nissan.
Thanks for the info guys :)
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
