Hey guys
Since some weeks I got this metallic sound from the rear of my car. At first it only appeared on the left, meanwhile on both sides.
It appears when I start moving the car, forward and reverse. Also when changing into 2nd and start accelerating.
It does NOT appear in every gear or always at the same "time". It sounds like 2 screwdrivers hit against each other.
Also you can not "make" that sound with "shaking" the car for example, so theres nothing haning around, nothing lose or not in place
and so on. A friend of mine is mechanic but we could only check without a lft but he couldnt find anything. Not the wheels, nor the suspension, not the exhaust, not the shieldings bla bla bla
I srsly got no clue what to do, and since a week, this guy has the same problem. Actually it´s not a real problem, at least so far. But everytime I stop and keep moving again, there´s that annoying sound and ofc that´s not how the car should be so I rly wanna fix that.
Sry for bad english, and sry for not being able to explain it better ^^
Here are two short vids, in which you can hear that sound. Sry for bad quality, cellphone sucks :) When you hear it, you´ll straight know what I am talking about.
Thanks a lot
http://www.dailymotion.com/video/k6mFvU0Vq7W3yw8kBlr
http://www.dailymotion.com/video/k1Am8JdGgI3N9O8flgQ
https://www.sau.com.au/forums/topic/445531-33-gtst-s2-metallic-noise/
I jacked the car up and tried to shake and turn the wheels in every possible direction. Should I hear it then too? Cause there was nothing. But I´ll have a look again.
if there play in the wheel when u tried? u might not hear it unless the wheel is under load being driven
Nah I´d say nothing. I turned and shook em in every possible way. Like said before, if you would hear it while checking, you´d also hear it while the whole is getting kinda rumbled by driving over a curb for example, I guess. But that doesn´t happen
Somebody meant while driving by might be something to do with the "struts" ( if I got the correct Translation ). I can´t see how this could be oO If, it would be more centre of the car, not obviously down and rear, correct?
A stainless exhaust can make a similar noise when tapped, on take off the exhaust will tend to move/vibrate more
also if there was some loose fragments of broken cat converter, they could be tapping inside the pipes.
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
