currently changing springs for my skyline iv did the rears and the bottom part of the shock slid back in car without a problem
though now im doing the front i cant seem to get the bottom of either shocks back in iv put my whole wight on the rotor stil not close..
is there some trick to this quite stuck atm?
Edited by KrazyTurk
Undo the ARB from the lower arm. Possibly also the caster rod. That will give you some slop in the LCA. If the car is up in the air, you could try a scissor jack under the LCA to change the angle to help convince the damper's lower mount to slide over the pin. A little spray of CRC or silicone lube might also help there.
Both wheels are off the ground? (had one years ago trying to do one side at a time)
Car supported on x-member, not on LCA?
As suggested, long prybar or crowbar to lever the hub down a bit - no need to disconnect anything else.
use the jack handle if its a big hydraulic jack
chassis rail and then on the lca
also have both wheels off the front and both sides swaybar and both sides shocks
basically anything that'll resist the lca's being pushed down
I used a block of wood myself putting stock shocks back in a jzx110 the other day had to use belly power to hold it down so my hands were free
