Hi. there's this turbo for sale and before I purchase it I want to know if it's a dud. I know the only way to find out is to hook it up but if there's anything you see wrong with it please tell me !!
Description:
Selling the OP6 turbo off my R34Gtt and the alloy intake pipe due to upgrading. In good condition, crappy plastic wheel replaced and flowed, made 240Rwkw at 16psi
Apparent Reason for selling is that he upgraded to a gtt 3076
He told me there's "a little bit of float but no end play, blew no smoke". He also suggested to put another bush kit on it.
Can someone tell me what that means ? Any help would be GREATLY appreciated. Don't want this to be my second bad turbo I buy
https://www.sau.com.au/forums/topic/445555-should-i-buy-this-turbo/
Buy new or high flow your own is my advice.
I'm not real comfortable when one member asks the collective about another members FS either.
The responsibility is yours and cant be shared on others to comment on pictures unless there is something glaringly obvious.
Your going to have to look at it in person before handing cash over
If buying the turbo will have other consequences such as world peace or three wishes etc the answer is yes you should buy it.
If you like taking risks to maybe save money then yes buy it.
If you like to put on and take off turbos just to see if they are actually rooted then yes buy it.
  • Like 2
Sorry it may seem harsh and it's a hard way to learn. It's never nice.
If the turbo you bought was from a member on here then leave him poor feedback and post in his original FS the facts. "Bought this Turbo and it was shagged"
May not help you but will help others.
Save up and get your original OP6 high flowed and get rid of the worry. good for around 245kw's hassle free
There are other things you will need
Larger injectors
Fuel Pump
Nistune & tune
about $3500 all up including labour and highflow
or if you want new and cashed up go the 3076 and take it to around 300kws
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
