Due to unforseen circumstances I have had to sell off parts from my uncompleted project.
Firstly the engine:
RB30DET
RB25DE stock head full reco with 110lb valve springs
RB30 block sonic checked and awd machined, with machining for tensioner pully relocation
CUSTOM side feed intake plenum with trumpets inside cost $1350
CP pistons 86.5mm
Spool Rods
ARP main, rod and head studs
NITTO OIL pump
NITTO crank collar
ROSS metal jacket balancer
NPC 10 inch clutch
TOMEI 1MM oil restrictor x 2
TOMEI SUMP baffle
HI OCTANE RACING awd SUMP adaptor.
NISMO engine mounts
6BOOST manifold
TIAL 60MM wastegate
BORG WARNER EFR 8374
DENSO 650CC low impedance injectors
TURBOSMART FPR800 with fuel pressure gauge
Custom Dual entry fuel rail
$700 of braided Teflon line for turbo oil feed, 2x water and 1x return.
YELLOW JACKET cool packs.
GTS4 AWD SUMP with 4.33 diff.
Engine is new! Has not been run yet! Looking for $16000.
Runs CP file back rings
ACL RACING big and mains bearings at .25
FULLY BALANCED ENGINE, engine pistons are also machine fitted to its specific bore and balanced accordingly. Machine work alone was $3500.
Also rebuilt r32gtr box so now 4th gear crunch $900
APEXI A.V.C.A.R $400
3INCH MAGNAFLOW 100 CELL CAT.$120
Walbro 040 $120
Fully rebuilt r33 GTST brake callipers full set $800 with rotors and new Lucas pads
https://www.sau.com.au/forums/topic/445561-rb30det-awd/
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
