im looking into upgrading my r33 turbos to the nismo n1 kit (http://www.ebay.com.au/itm/Turbo-N1-Upgrade-Kit-R32-R33-GTR-RB26-RB26DETT-NISMO-/120514498456) link to N1 turbos on ebay.
if i do get this kit will it be safe to put in my gtr i dont have a N1 block will this matter.
https://www.sau.com.au/forums/topic/445570-n1-turbo-upgrade-r33-gtr/
^ what he said, and they have bush bearings and may well be old tech laggy wheels. Just go straight to -7s (aka R34 N1s) or -9s. Its a lot of work to change turbos and they make a big difference to how the motor runs, so if you skimp you'll regret it. Only other option would be to contact Hypergear to what he has to offer, but usually the cost of a proper rebuild/highflow is too close to the -7s so its just not worth it.
There's no difference between the blocks with respect to manifolds and mounting of turbos.
... do yourself a favor and find a mechanic with plenty of gtr/skyline experience before you buy anything!
That kit is neither N1 nor Nismo however is a waste your money. As with everything in life you get what you pay for. What you're after is a set of direct bolt-on Garrett GT2860R-7s (AKA R34 N1). If you'd like some advice or a quote drop me a line.
  • 5 months later...
Hey Kudos,
I've got a 33 gtr. I was planning on upgrading the stock turbo's to -7's or possibly -9's though I noticed you have the 2871r-10's. Do you think these would be too small? I know there are plenty of threads on -5's vs 7's & 9's. Ultimately I'm trying to build the car for response and reliability. As guys who work on GTR's day in and out I was keen to know what you think the go would be??
Cheers
^ Do yourself a BIG favour - and research. -10s are the WORST possible selection you can make. Rubbish turbos, far too big.
Totally agree.
$200 turbo "upgrades" forget it - it's $2200 for a set of -9s or -7s or don't bother spending the money.
The N1 / bush journal setups are 1980s design, lack performance that has been well and truly superseded by more modern turbos and the extra response, power and performance is worth the money.
Turbos are the most important part, don't skimp on them or regret it forever.
  • Like 1
Hi jnbR33, as R31Nismoid the GT2871R-10s aren't a great selection for the RB26 and for response the -7 or -9s are the best option with the -9s being the most popular these days by a country mile.
N1 'upgrades' don't really fit into the word 'upgrade' as it's almost a backward step using out-dated tech and the only average-at-best performance you get from them.
R34 N1s however, good upgrade - but they are a "-7" turbo anyway really, so just buy new and don't worry about it
depends really doesn't it? if you spend that money on the parts how much would 2 rebuilds cost to be installed and balanced by a turbo builder? $500-600? probably alot cheaper than 2 new turbo's?? i'm not saying you guys are wrong i'm just saying they might be a good option for someone on a budget.
Well the cost would be roughly $1000 (worst case of course) for two turbos by the time you buy the parts, send them off to be assembled/balanced.
So yeah it most certainly is cheaper... But they are soooo much laggier. We are talking laggier than a -5 turbo (capable of 400rwkw) but they will only make the power of a -9s (340rwkw).
That's not really a good option in anyones books to have all the lag without the power. Pretty hard to justify that being an 'upgrade'.
You'd be better off taking the chance with a 2nd hand set of -9s for $1200-$1400 and getting them inspected.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
