Looking to purchase some bits for my bus and seeking some places to look for lowest prices, have been out of the import scene for a while so not sure where to look.
Had no real luck on injectors so far keen on SARD, Bosch, NISMO, HKS or similar; direct swap with factory ones for BNR32 650-800cc
Thanks in advance from any help
https://www.sau.com.au/forums/topic/445575-where-to-buy-new-injectors/
All those injectors were designed 20 years ago, you are better off getting modern 14mm top feeds and adapting them to suit the old 11mm rail.
If you would like some prices give me a PM, and don't limit yourself to 800cc, you will need much bigger if you ever decide to run better fuel... If Queensland ever gets e85 at the pump...
Reg and fittings.
There is no need though, plenty of guys running 14mm injectors with 11mm adapters on top...
http://scottyscustoms.com.au/product/1000cc-xspurt-to-suit-rb26-stock-rail/
These idle fine, even in the larger sizes, unlike the old Sard style injectors.
