The sequence you describe does not make sense.
Pages CH348 + 349 of the R32 GTR manual tell you that it should give error codes in numerical order. So if you do have a 2 flash and a 3 flash code, they should come 2 first then 3. Not in reverse order like you describe.
Just FYI, 2 is LH solenoid output (which is one half of the unit in the engine bay) and 2 is the failsafe valve (which is in the rear). 4 is the code for power steering solenoid output.
You should get it onto a proper Consult unit to read the codes more easily. There's definitely something wrong.
https://www.sau.com.au/forums/topic/445597-hicas-problem/#findComment-7338158
Went to nizzpro performance they had a second hand hicas computer, put it in all good no more hicas light when I'm driving anymore, did diagnostics after instilation and still getting a code from the hicas light, instead of being 4 1 sec interval flashes 3 long 2 quick and one extra long it's now - 4 1 sec interval flashes 1 long 4 1 sec interval flashes and one extra long???
https://www.sau.com.au/forums/topic/445597-hicas-problem/#findComment-7341383
Get the manual. Compare with the pictures on the pages I indicated. We'll never be able to work it out from your descriptions. "Super long" means what exactly? And you need to take careful note of the starting point in this sequence. None of the sequences in the manual start the way you describe.
https://www.sau.com.au/forums/topic/445597-hicas-problem/#findComment-7341486
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
