ok this is a different question to Waz's...
I got a 3" cat back installed on Friday (hi-flow cat, 3" piping w/ 4.5" cannon) it's damn loud...as in I don't think I'll pass the EPA dB test.
Question is, how do I make it quieter? Or should I change back to 2.5"?
The other thing is when it's idling it sounds a little lumpy. Now the car's fairly stock. The only mods I'm aware of are the ones I've done (front mount, pod). There is also a Blitz BOV. Just wondering if this lumpy sounding idle is normal or does it sound like my car had some previous work done that I'm unaware of.
https://www.sau.com.au/forums/topic/44560-3-exhaust-on-r32-gts-t/
nah cereal your car just has that crazy note from the exhaust.
its probably not that bad but you are soft :rofl:
get an exhaust shop to fit a resonator should quiten it down a bit.
but you will loose power.
so dont come back grumbling I want more power :rofl:
any way have a listen to my car that has a similar exhaust but on an sr I have no hassels with it but I dont fang it through shopping centers etc.
teh efficence of turbo all come back to how quickly you can get the exhaust out with out restriction.
vid is here http://www.meggala.com/ceffyshort.MPG
cheers
meggala
this is why i was thinking of just going to a 2.5" cat-back...
how does a resonator work? is it straight-through in design like a muffler and how does it rob power?
you could just run 2 resonators if it will only lose you 5kW overall (a fair sacrifice in my opinion for ride comfort.
Mine is pretty quiet but i am running a 3" cat, centre and rear mufflers.
I would think that throwing a centre muffler / resonator could be the answer.... my old R31 has a custom 3" exhaust with only a rear muffler and a high flow cat, and it sounded absolutley wicked, loud sure but so much better then my R32, mind you it did have a pretty on/off T3/4 as well.
Me thinks cat and two mufflers is the way to go, just make sure they are good quality straight thru mufflers and they shouldnt knock the power around too much on a car with std turbo, or slightly biiger aftermarket jobbie.
Yer mines not loud at all.
With my other half driving my car normally and myself in a dunga door VN with the windows up I can't even hear my 32.
When she gives it stick I can hear it a little, when I put the windows down it is loudish but not a crude loud that is over the top. It is definately louder than some of the jap exhausts I've heard though.
I mentioned before I've got a turbo back 3", 3" cat, large center resonator and a large rear muffler.
Here's a pic of the rear muffler I am using.
And another before the pipes are welded on.
The resonator.. (Pics from a R33 GTR they also done)
And the Cat.
exhaust noise = power :)
mine is 3", race cat :) and only the rear N1 muffler, almost completley straight through - its reasonably loud, but I love the sound of it, especially under a bridge or through a tunnel. It had the centre muffler section, but this was removed due to clearence issues getting into my car park at work.
Clint32 replaced the centre muffler section with straight through 3" and tucked the exhuast closer to the chassis
Been through bretho's etc, and under idle its reasonably quiet, no cops have ever looked twice at it. I'd say it would be very close to, or over the legal limit. Sets car alarms off in car parks sometimes
I'd say if you can put up with it, stick with the 3", and maybe get a resonator put in near the diff/cradle, as that will knock a few Db from it
I am thinking of putting the centre muffler back in, on long drives it can get a bit loud, so might whack it back in.
Try a resonator, you might loose a few rwkw, but thats the trade off for a bit quieter exhaust
Chris
Hi cerealeater, we always fit 2 mufflers to road cars, one around the gearbox (called a resonator by some) and one at the rear. Whether it is a 2.5", 3", 3.5" or 4" system we specify 2 mufflers, this fixes the resonance the annoying at certain rpm's. The power loss (if the mufflers used are efficient) is neglible. It's no good having an extra 20 rwkw if you can't drive the car because of the exhaust noise.
Hope that helps
i think i might get mine done in 3" (already have 3" dump/front), going:
turbo-> 3"dump -> 3" front -------> 3"cat -> 3" muffler -> 3" resonator ------------------> 3" cannon muffler
all straight through in design and all the same diameter
fair trade off for the power me thinks :)
(those lines are suppost to represent the approximate distance of pipe beween each component)
i have a 3inch straight thru and had a 5 inch muffler and it was to loud so i went and spoke to a muffler shop and they showed me a few mufflers that they thought would do the trick so i picked one and it worked perfectly and didnt notice a drop in power, but dont ask me the brand cause i would not know.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
