sama1500 Posted July 14, 2014 Share Posted July 14, 2014 hey im new here so dont really know much about this but i was wanting some help, currently got an r32 gtst, fairly standard with the only mods being front mount, pod filter, rb25 turbo and boost controller set at 12psi, dont know how much power its currently making but im wanting to chase more power in the future but nothing crazy, i'd like to keep the responsiveness of the current turbo but run more boost so im guessing i need a better turbo, injectors and a tune, any suggestions? Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/ Share on other sites More sharing options...
R_34 Posted July 14, 2014 Share Posted July 14, 2014 Search button will help you. And begin with the rb20 dyno thread, there is a lot of useful info in it on what to do. It depends of the country you live in. Some country are much more tolerant than others with modified cars. Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339045 Share on other sites More sharing options...
sama1500 Posted July 14, 2014 Author Share Posted July 14, 2014 thanks , i live in australia, not really after massive performance just a bit more power with good response Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339098 Share on other sites More sharing options...
Sinista32 Posted July 14, 2014 Share Posted July 14, 2014 Much more boost and you will blow your trubo (if it is stock) Cost effective option for more KW's with same response Cam gears, Highflow the Turbo you have, upgrade your injectors, have the ECU nistuned and tuned. Maybe upgrade your fuel pump and a free'r flowing exhaust if it's stock. The RB20 dyno thread will give you what people have modified to get the stated power figures and specifics of the upgrades. Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339155 Share on other sites More sharing options...
sama1500 Posted July 14, 2014 Author Share Posted July 14, 2014 thanks heaps, ive already got a full 3 inch exhaust except for the dump pipe which is stock, would it be better to get an ecu or just get the stock ecu nistuned? Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339203 Share on other sites More sharing options...
R_34 Posted July 14, 2014 Share Posted July 14, 2014 Stock ECU + nistune is fine. No need for more if you're chasing little power. Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339206 Share on other sites More sharing options...
Sinista32 Posted July 14, 2014 Share Posted July 14, 2014 just Nistune Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339207 Share on other sites More sharing options...
sama1500 Posted July 14, 2014 Author Share Posted July 14, 2014 sweet, as for injectors im assuming some gtr injectors would be fine? fairly sure they're 444cc from memory Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339217 Share on other sites More sharing options...
sama1500 Posted July 14, 2014 Author Share Posted July 14, 2014 also no idea on what high flowing a turbo is haha, first jdm/turbo car so i have no idea what im doing Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339227 Share on other sites More sharing options...
R_34 Posted July 14, 2014 Share Posted July 14, 2014 (edited) Yep they're 444cc but low impedance. You'll also need the resistor box and wire it up. I chose the deatschwerk injectors as these ones are drop-in. They're perfectly fine for now albeit noisy. Idles good at a steady 15 AFR and I have something like 70% duty max @20psi. Mines were 458cc in average, ranging from 451 to 465cc if my memory serves me right. If I ever convert to E85 I will pick the 650cc ones. Highflowing a turbo means replacing compressor and turbine wheel with larger parts with new bush bearing on ball bearing converison. Check with hypergear or kinugawa turbo. I ran the kinugawa one, but I wouldn't recommand it if you're chasing the responsiveness of a stock turbo. Hypergear should have smaller turbo more suited to your liking. Edited July 14, 2014 by R_34 Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339228 Share on other sites More sharing options...
sama1500 Posted July 14, 2014 Author Share Posted July 14, 2014 thanks heaps! i'm chasing around 180rwkw (or more) so would all this be enough to get there? Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339237 Share on other sites More sharing options...
R_34 Posted July 14, 2014 Share Posted July 14, 2014 No need for a bigger turbo then, the 25 turbo if healthy can bring you there but no more. At least not safely in the long run. If you keep the 25 turbo I woul install a FMIC as the 25 compressor wheel is not very efficient. AFM will be big enough, oem injectors are a tad short to be safe I guess, CA18DET injectors (370cc) with a rb26 resistor will do the job easily, on pump gas at least. I don't know about the clutch capability. Mine was blown when I got the engine so I upgraded it directly. Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339248 Share on other sites More sharing options...
sama1500 Posted July 14, 2014 Author Share Posted July 14, 2014 i'll probably end up chasing more power in the future anyway and it is my daily so i'd rather not push the 25 turbo too far, so for now injectors, turbo and nistune should get me over 180rwkw, also the previous owner said there was already a heavy duty clutch in there so i should be ok there Link to comment https://www.sau.com.au/forums/topic/445628-rb20-performance/#findComment-7339257 Share on other sites More sharing options...
