hey im new here so dont really know much about this but i was wanting some help, currently got an r32 gtst, fairly standard with the only mods being front mount, pod filter, rb25 turbo and boost controller set at 12psi, dont know how much power its currently making but im wanting to chase more power in the future but nothing crazy, i'd like to keep the responsiveness of the current turbo but run more boost so im guessing i need a better turbo, injectors and a tune, any suggestions?
https://www.sau.com.au/forums/topic/445628-rb20-performance/
Search button will help you. :whistling:
And begin with the rb20 dyno thread, there is a lot of useful info in it on what to do.
It depends of the country you live in. Some country are much more tolerant than others with modified cars.
Much more boost and you will blow your trubo (if it is stock)
Cost effective option for more KW's with same response
Cam gears, Highflow the Turbo you have, upgrade your injectors, have the ECU nistuned and tuned.
Maybe upgrade your fuel pump and a free'r flowing exhaust if it's stock.
The RB20 dyno thread will give you what people have modified to get the stated power figures and specifics of the upgrades.
Yep they're 444cc but low impedance. You'll also need the resistor box and wire it up.
I chose the deatschwerk injectors as these ones are drop-in.
They're perfectly fine for now albeit noisy.
Idles good at a steady 15 AFR and I have something like 70% duty max @20psi.
Mines were 458cc in average, ranging from 451 to 465cc if my memory serves me right.
If I ever convert to E85 I will pick the 650cc ones.
Highflowing a turbo means replacing compressor and turbine wheel with larger parts with new bush bearing on ball bearing converison. Check with hypergear or kinugawa turbo.
I ran the kinugawa one, but I wouldn't recommand it if you're chasing the responsiveness of a stock turbo. Hypergear should have smaller turbo more suited to your liking.
Edited by R_34
No need for a bigger turbo then, the 25 turbo if healthy can bring you there but no more. At least not safely in the long run.
If you keep the 25 turbo I woul install a FMIC as the 25 compressor wheel is not very efficient.
AFM will be big enough, oem injectors are a tad short to be safe I guess, CA18DET injectors (370cc) with a rb26 resistor will do the job easily, on pump gas at least.
I don't know about the clutch capability. Mine was blown when I got the engine so I upgraded it directly.
i'll probably end up chasing more power in the future anyway and it is my daily so i'd rather not push the 25 turbo too far, so for now injectors, turbo and nistune should get me over 180rwkw, also the previous owner said there was already a heavy duty clutch in there so i should be ok there
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
