Heaps of places to eat, but the 3 I listed are places you're going to want to sit down and order something decent, all of which are easily accessed from the highway and easy to get back to it.
Glenrowan has a Maccas right on the highway, it's an hour south of Wodonga. Next Maccas is Yass which is a good few hours further North. Plnety of fast food places close to the highway exits here too.
Just not sure how filthy you want to eat :D
Edited by ActionDan
Cheers mate, I'm picking someone up in Wadonga so I'll be sitting down for a proper breaky and will check out one of the joints you listed :)
If you're specifically "in" Wodonga then none of those might be a good choice as they're all in Albury - La Maisons is on the causeway between the two towns though.
In Wodonga you can try Cafe Grove in High Street or Cafe Elmwood on Beechworth Road.
If you go to La Maison's and Wasim is there, looks like a younger plumper Sylvester Stallone, tell him I said Hi and to look after you.
No worries, thanks for all the tips. Cafe Grove is where I stopped last year so might check out Cafe Elmwood for something different.
Now it's time to knock off work and clock on the cans. See ya up there boys.
Might catch you there - Maybe I should wear a name tag....
Can't remember if I asked this.
Is there any drinking at WTAC? I assume there is no BYO.
think I recall someone saying something about a bar? I assume that price gouging comes as standard?
Not looking to get hammered, but not opposed to a few bevvies.
Any rules on this? Is a six pack the limit?
Also I'm not familiar with EC layout in terms of parking myself and an esky somewhere? Grandstand?
Camping chairs a good idea?
Edited by ActionDan
they say no alcohol permitted outside the bar areas. they dont have a shit ton of security and so long as ur not walking the pits with a bottle of jack or some cans I say u will be fine..
setup on the hills or in the grandstand down em and then go for a walk
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
