I've listed a new ad as some parts have changed and the price/pics have been updated to reflect this. I have found a car that I wish to purchase as a replacement so take a look!
Everything works well, A/C is cold & the car is mechanically fantastic. It has been modified to drive like a standard car with usable power. The body has some blemishes but overall it is in great condition. Please note the car will be sold with 17" Impul rims. I will also include various stock parts such as exhaust etc for an easy RWC which can be arranged.
Car: 1998 Toyota Chaser JZX100
Transmission: Factory 5MT
KM: 126xxx
Registration: Valid until May 2015
Colour: 6n9
Price: $18,000
Contact: Michael 0424 141 211
Maintenance
100k service & general services completed
New OEM diff bushes
New clutch master & slave cyls
Mods
Power
Blitz K1-450V Turbo w/HKS Actuator
Blitz FMIC
Denso 850cc injectors
Walbro 255LP/H fuel pump
Trust DD twin pipe exhaust
Koyorad 2layer copper radiator
TRD Radiator cap
Action Stage 3 clutch
HKS F-Con V Pro V3.14 ECU w/3Bar map sensor
Tuned by Trent @ Chequered Tuning. Makes over 240RWKW & 470NM of torque by 3200RPM
Brakes/Susp
Znoelli slotted front rotors & pads
Tanabe coilovers
TRD sway bars
Tom's triangle brace
Interior/Exterior
OEM lip kit & weathershields
Clear side indicators
Clearworld smoked corner indicators
TRD gear knob
Stereo with alpine head unit/amp/speakers
Mongoose M80G 3pt immobilizer/alarm/keyless entry
Pics
Edited by discern
  • 3 weeks later...
Price drop! Car is now for sale with the basic bolt-ons (coils, cat-back, fmic, rad, trd bits) for $16,000 !!
Would make a great daily drive/weekend fun car being 5mt stock-ish comfortable etc :)
Edited by discern
  • 5 weeks later...
  • 4 weeks later...
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
