I've listed a new ad as some parts have changed and the price/pics have been updated to reflect this. I have found a car that I wish to purchase as a replacement so take a look!
Everything works well, A/C is cold & the car is mechanically fantastic. It has been modified to drive like a standard car with usable power. The body has some blemishes but overall it is in great condition. Please note the car will be sold with 17" Impul rims. I will also include various stock parts such as exhaust etc for an easy RWC which can be arranged.
Car: 1998 Toyota Chaser JZX100
Transmission: Factory 5MT
KM: 126xxx
Registration: Valid until May 2015
Colour: 6n9
Price: $18,000
Contact: Michael 0424 141 211
Maintenance
100k service & general services completed
New OEM diff bushes
New clutch master & slave cyls
Mods
Power
Blitz K1-450V Turbo w/HKS Actuator
Blitz FMIC
Denso 850cc injectors
Walbro 255LP/H fuel pump
Trust DD twin pipe exhaust
Koyorad 2layer copper radiator
TRD Radiator cap
Action Stage 3 clutch
HKS F-Con V Pro V3.14 ECU w/3Bar map sensor
Tuned by Trent @ Chequered Tuning. Makes over 240RWKW & 470NM of torque by 3200RPM
Brakes/Susp
Znoelli slotted front rotors & pads
Tanabe coilovers
TRD sway bars
Tom's triangle brace
Interior/Exterior
OEM lip kit & weathershields
Clear side indicators
Clearworld smoked corner indicators
TRD gear knob
Stereo with alpine head unit/amp/speakers
Mongoose M80G 3pt immobilizer/alarm/keyless entry
Pics
Edited by discern
  • 3 weeks later...
Price drop! Car is now for sale with the basic bolt-ons (coils, cat-back, fmic, rad, trd bits) for $16,000 !!
Would make a great daily drive/weekend fun car being 5mt stock-ish comfortable etc :)
Edited by discern
  • 5 weeks later...
  • 4 weeks later...
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
