Ok got baby on the way soon and Mrs wants the spare room sorted and garage cleaned out pronto. Car looks like it's sold and I've got a bunch parts that have to go. Some I brought over from Japan for people who never paid for them and have been sitting around taking up space, gathering dust and driving the misso up the wall.
2 x Brand new genuine SPLITFIRE COILPACKS unused.
SF-DIS-001 (suits GTR32 and GTR33) $475 posted
SF-DIS-005 (GTR34) $475 posted
2 x Brand new TOMEI EXPREME Turbo Outlet Pipes (Dump) $690 posted
1 set for GTR32 + GTR33, Other for GTR34
In box never used
NISMO 320 KPH COMBINATION METER (Black) Used $285 posted
Good cond. 153,927 km's
NISMO 320 KPH COMBINATION METER (Black) Brand New $595 posted
NISMO GT TITANIUM SHIFT KNOB Brand new $125 posted
SARD ADJUSTABLE FUEL REGULATOR TYPE-RJ Brand new $250 posted
Universal type (For 8mm fuel hose)
SUPERIOR AUTO CREATIVE CARBON SHIFT PANELS
GTR33 and GTR34 Both Brand new never used $200 delivered
Have one of each !!
CARBON GRILL For GTR33 Brand New $320 posted
Comes with brand new GTR ornament
GENUINE TAKATA MPH341 4 POINT HARNESS Brand New $300 posted
Needs mount bolts, easy to get from Auto Pro etc
QEST LED Front bar INDICATORS for GTR33 Brand New $265 posted
These use brand new genuine Nissan housings so perfect fit.
R33 JAP STYLE NUMBER PLATE Brand new $50 posted
Got more parts I have to sort out and will post later
Can I take the carbon stuff for the r34 Gtr please
Sorry the Carbon gear for R34 is sold !
SOLD
Splitfire CoilPack SF-DIS-001 SOLD
TAKATA Harness SOLD
SUPERIOR AUTO CREATIVE CARBON SHIFT PANEL for R34 SOLD
NISMO GT TITANIUM SHIFT KNOB ON HOLD
TOMEI EXPREME Turbo Outlet Pipes ON HOLD
Everything else still for sale !!
TOMEI GTR34 Dump pipes SOLD
TOMEI EXPREME Turbo Outlet Pipes (Dump) $690 posted STILL AVAILABLE
STILL FOR SALE
SPLITFIRE COILPACKSSF-DIS-005 For R33 RB25DET Series 2 and R34 RB26DETT GTR
Brand new genuine unused. $475 posted
In box never used
NISMO 320 KPH COMBINATION METER (Black) Used $285 posted ON HOLD
CARBON GRILL For GTR33 Brand New $300 posted
NISMO 320 KPH COMBINATION METER (Black) Used $285 SOLD
STILL AVAILABLE
In box never used
They are the Newer ones.
The garbage you hear about the older ones being better is a load of crap.
New design was tested for better flow and less disturbance than the old ones plus.
Tomei engineers are not idiots, if the old design was better they would have kept it.
The old ones had two welds and caused a slight disturbance in flow properties, new design has been flow bench tested and flows better , less disturbance and hence less restriction. It's not about bigger being better, ask any sexaholic chick that, it's about performance and nice smooth flow !
I've been over this with Japanese engine builders and seriously , if the old design was better then that's what Tomei would be selling. I'm not trying to convince you to buy these, just I've sat down with multiple race engine builders in Japan and been through the myth that the old style are better.
pm answered
Brand new genuine unused. SOLD
STILL AVAILABLE
In box never used
Exchange rate has moved so
Brand new TOMEI EXPREME Turbo Outlet Pipes (Dump) $675 posted
1 set for GTR32 + GTR33 In box never used
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
