....No I'm not. I'm looking for it because the shape is perfect for my setup and secondly most places on the sunshine coast don't put this quality of workmanship into things they do. They're too slap happy. Also I have a 6inch short pod sitting at home given to me. So it's not about wank factor or any crap like that. That's just a premature naive assumption.
Edited by RobG85
I could make it, but unless you are pushing 11ty kw an 80mm intake will do the job. I have run mine up to 400+kw easily, and the engine bay remains stealth. I am guessing you have a huge top mount though?
A funnel like that isn't going to improve flow much from my experience, just get you defected on the road. If it's a track car, go for your life.
Yes I am running a big high mount. Efr 8374 to be exact. Legally, as long as the pipe is secure it is legal. The object is to start this thing at 380 to 400 awkw and go from there. Assuming based on area and potential cfm flow I could see how it would potentially work with higher power levels, thus would be beneficial to buy one intake pipe and fit it, then go through 2 or 3 setups to alleviant better airflow from restrictions later down the track. I also have custom pipe work needed to be done too. You in qld Scott?
Edited by RobG85
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
