Hi. I'm thinking about buying an apexi avcr and installing it into my fully stock, auto r34 gtt. Will I have any problems in doing this ? Will it cause my ecu to go crazy? Couldn't find any answers I'm looking for in the forums so if anyone knows about any harm this could cause it would be greatly appreciated !
Not trying hard enough. Quite probably the single most over asked and exasperating question on these forums ever. I personally have answered it more times than I can count, and I can count quite a lot.
Would a re4r01a shift kit work? I can't find any for re4r01b. If someone has a link to a cheap seller of this item as well it would be greatly appreciated
Nope.
Mv automatics.
Nope.
Mv automatics.
^^ This. MV do swap over valve bodys, but they had run out recently so I hear, as none of the customers had returned them. Worth a call anyway.
I contacted mv and they said they could do it for me if I send them my valve bodies. I don't want to have to go to a mechanic and leave my undrivable car there for a week while my valve bodies are getting work done to them over east. Do you guys think it's a good and cost effective idea to remove them and do the work myself? Also to remove the tranny would I need a crane or would I need to jack the car up ?
Once again thanks for all the help I'm getting , I really appreciate it !!
It's a messy job.
Dropping the valve body isn't that hard, but you need to keep track of where all the bolts came from for when you reinstall everything, and there are a LOT of bolts.
Package it well, otherwise you will need another transmission.
I tried a bleed valve on my stock GTT and it really didn't achieve anything to run more boost. exhaust is restrictive and I'm pretty sure I logged it pulling timing out using ecutalk. There was a noticeable dead spot in the midrange. That was only a small boost gain too.
Gotta do the other breathing mods first (exhaust/FMIC). I will be going Adaptronic / hypergear high flow / ID1000 after that anyway. Wheeeeee! :)
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
