How long does an Rb25det take usually to get to operating temperature?
I noticed that mine takes ages to even start registering on my temp gauge.
I haven't checked the thermostat yet, I'll get to it shortly.
Also, while on the subject, what is the ideal temperature for an rb25det?
Thanks.
https://www.sau.com.au/forums/topic/445813-rb25det-warm-up-time/
It depends on a lot of factors, including the start temp, but the thermostat does the bulk of the work. I would have pulled it out and checked it in boiling water, it would have taken less time than typing the post. :P
Stock temp? Anything around 80 - 90 degrees C would be fine.
Mine only takes about 5 mins if I drive it. Is fairly quick to warm up
Thats just gently driving it, I dont give it anything till its warmed up
Not sure what makes mine different, Even starting in cooler weather of 10 degrees or so doesnt really take it much longer to warm up
Haha, I was sleeping in on my day off so there's no way I was going out into the cold lol.
My car takes a good 20 minutes idling or 15 minutes driving to even start reading on the temp gauge!
Going to pull my thermostat out tomorrow to see if it's leaking...
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
