I'm trying to fit a Nismo s-tune strut bar with brake stopper to my r32 gts4 rb25det.
Firstly the brake stopper didn't line up so I've had to just rotate it for now, so it's misaligned but at least two edges are in contact with the master cylinder.
When trying to connect the bar - at the driver's side - the bar won't line up in the hole properly so the bolt doesn't go in. This is because the bar goes directly over the intake pipe and fouls on the last black joining hose.
It appears to be just millimetres too high. From what I've seen the rb20 plenum/intake is positioned closer to the firewall so it's not a problem.
Anyone else come across this issue? Would washers or spacers under the plates be okay?
Cheers.
https://www.sau.com.au/forums/topic/445815-front-strut-bar-wont-fit/
I've got the same strut bar, you will need to rotate the stopper a bit more so it sits flush.
Maybe once you fix that, the rest will fall into place?
Here's pics of mine
Edit: Oh wait, I think that strut bar only fits R33 and R34? And not R32?....
Yes, it's an R32 strut bar.
Charles89 - I intentionally aligned it that way. From that picture if I rotate it clockwise only 1 edge will be in contact with the MBC (it's that much offset). So that one gold edge will be sitting against that diagonal bit, hope that makes sense.
blind_elk - is yours a Neo? Forgot to mention that mine is a Neo, but you can probably see that from where the traction control module would be mounted.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
