10437506_10153184802724386_2020716188013
The SAU Vic 2014 Go Kart Series is run the last Sunday every 2nd month at several different Karting venues around Melbourne. This year has 3 rounds of racing with trophies/prizes awarded to the top 3 places at the SAU Vic Go Kart Series end of year meet and award night held after the last race.
Rounds are run as per venue rules and points are won just like a 2014 F1 race (without doubles points for the last round) –
1st - 25pts 2nd – 18pts 3rd – 15pts 4th – 12pts 5th – 10pts
6th – 8pts 7th – 6pts 8th – 4pts 9th – 2pts 10th – 1pt
The second round takes the series to ACE Karts on their 700m long track. 12 corners, wide track for overtaking and a 41:00sec average lap time should make for some great racin10447654_10153184948164386_7250134300976
Entry to the event is $80 per driver which includes -
  • 10min Qualifying Session
  • 20min Race
  • Trophies for 1st, 2nd & 3rd
  • BBQ provided by SAU Vic (bring a side to share if you can)
This is an open event to members and non-members of SAU Vic so feel free to invite a friend or family member to join in on the fun!
11:30am meet with a 12:00pm race start.
To enter simply show your interest here and have your name added to the list then pay on the day of the race.
You can also send in your race fees to secure your spot for the day to -
Name: Skylines Australia - Victoria
Bank: Westpac
BSB: 033305
Account: 265609
For a reference when you make the payment put - 'GK2 forum-name' - so we know who paid and what you are paying for.
There are limited spots open so get your name/race fees in to secure your place on the grid for the second round of the SAU Vic Go Kart Series!
Driver List -
Tony O
Simon + Ray and Simone
Lee
Michael + friend
Sam
John
https://www.sau.com.au/forums/topic/445820-round-2-sau-vic-go-kart-series/
  • 4 weeks later...
BTW not sure want happened with ACE timing if it was meant to be 10min Qual, 20min race. Due to them messing up scheduling we started 30mins late, they said they'd give us qual and two races to give us a bit extra track time as compensation.
Going off footage what we actually got was 14min qual, 14min race?
Yeah when I spoke to them it was 10 minutes qualifying, 10 minutes practice and 15 minutes final race. I gave up in the practice after my arms were killing, hoping I'd rest a bit for the final, obviously not :P
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
