1. R34 centre console with leather handbrake boot - SOLD
2. R34 series 2 silver headunit surround - SOLD
3. R34 series 1 triple gauge cluster (no surround) - $60
4. Apexi Power Intake - SOLD
5. Blitz SUS Power pod (comes with R33/34 AFM adapter) - SOLD
6. R34 series 2 silver ashtray - SOLD
7. R34 series 1 black ashtray - SOLD
8. R34 cig lighter - $10
9. R34 Nismo clear side indictors - SOLD
10. R34 leather centre console lid (with perfect hinges) - $60
11. R34 RHS reverse light - SOLD
12. R34 stereo bracket - $15
13. R34 series 1 floor mats (2 wear marks on drivers, but the rest are pretty much perfect) - $100
14. Nismo oil cap, used - SOLD
15. R34 boot lid trim - $30
16. Nissan cat cover (not sure where it came from) - $20
17. R34 front indictors - $30
18. R34 boot brake light - $30
19. R34 Taillights - $140
20. RB25 coilpack cover - $30
21. R34 wiper arms (no rust at all) - $60
22. R34 boot plasitc trim - $20
23. R34 Speedo surround - SOLD
24. R34 ac vents - SOLD
25. R34 climate control (not the best condition) - SOLD
26. R34 stereo surround trim (has a few small marks) - SOLD
27. R34 plastic windscreen trim - $40
28. R34 scuff/kick plates pair (perfect condition) - $90
29. R34 LHS scuff/kick plate (perfect condition) - $50
30. R34 rear parcel shelf - $30
31. R34 door cards with Pioneer tweeters - SOLD
32. R34 complete boot trim (not pictured) - $80
33. R34 GTT rear seats - $120
34. R34 GTT OEM radiator - SOLD
35. R34 GTT OEM coilpacks (all 6 was working when taken off car) - SOLD
36. R33 ARC super induction box (no filter) - SOLD
37. R34 GTR rear seats - SOLD
38. Carbon Fibre NACA Duct - SOLD
Can provide more pics upon request.
Pick up from SE Melbourne, can post at buyers expense.
post-40415-0-32428900-1405743594_thumb.jpgpost-40415-0-88725700-1405743605_thumb.jpgpost-40415-0-60355600-1405743628_thumb.jpgpost-40415-0-03844900-1405759661_thumb.jpgpost-40415-0-30420200-1405759670_thumb.jpgpost-40415-0-28513800-1428032531_thumb.jpgpost-40415-0-92600400-1428032538_thumb.jpgpost-40415-0-98878100-1428032552_thumb.jpg
https://www.sau.com.au/forums/topic/445826-garage-clean-out-r34-parts/
1. R34 centre console with leather gear boot - $80
Is this the manual shifter trim (part below on the right)? If so, I'm keen, and might also grab the triple gauge cluster.
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
