Hey there everyone. R32 GTR on nistune with pretty much all bolt ons. 18-19psi and 310atw. Running GTSS and a cat on 98 pump. It was tuned a little rich to be on the safe side I guess. Noticing that on initial boost after warm up or cruising off full boost for a while that I'm puffing a blackish cloud out. Only once though. I realise it's the nature of the beast to smoke under poke. Just wondering what this initial boost cloud is all about. Built up fuel, carbon? Cat converter? Shit fuel??? Any suggestions or information would be greatly appreciated.
https://www.sau.com.au/forums/topic/445833-puff-of-smoke-on-first-boost/
Slightly too much fuel in the boost transition. Might just be the difference between the loads that the tuner was seeing on the dyno compared to the actual loads you get whilst on the road. You could do a log of a few boost transition runs and see which cells it's passing through and compare with where the tuner remembers it being (or run it on the dyno again to see if it's different). Could subtract a little fuel or just live with it as it is basically pretty safe.
  • Like 1
The upgrade is just over 10k km's on now and has always left a bit of a stain on the ass being a white gtr. It's going in for a touch up tune next Saturday. Guess we can have a look at what's happening then. Once it's had a puff though there's no real smoke again. Unless stop start traffic for a while and cruising then just that initial boost. Has all new gear. Z32's, turbos, injectors, pump, controller, etc. Thanks for input guys. Just a paranoid 32 owner I guess...
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
