On my 2004 Nissan Stagea 350RX where does a OBD 2 scanner plug in, and if I buy a scanner what brand would be a good suggestion, I see hundreds of them on Ebay, what am I looking for, they seem to start at about $20 up to $180.
Cheers in advance Harry
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/
I thought the 350 would work with any OBD2 scanner, as it was made after mid 04 when the OBD2 laws came out in Japan.
You would still need the Consult 3 for detailed diagnostics on all the ecu's in the car, the generic ones would only pick up the engine I think.
Where are you located Harry? Someone local might have something you can try out before you buy...
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/#findComment-7344562
Hi Scotty, I am in Wellington, New Zealand. New to the Stagea thing, I have an engine light on and want to learn more about all this, the engine has to crank over about 6 to 8 times cycles before it starts, from what I have read on here it probably is a cam angle sensor. I have rad the manual way of reading codes, just have not tried it yet.
Thanks for your help.
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/#findComment-7344659
Either crank or one of the cam sensors is faulty. Have you tried cleaning them? Sometimes metal shavings from the starter motor build up on the magnetic crank sensor as it is at the bottom of the bell housing, this can cause issues with starting.
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/#findComment-7344997
i have a obd2 scaner creader i believe the name is and it talks just fine to the stags i just use the infiniti option and automatically select car it does o2, maf as well as helped me work out which abs sensor was dead
Very interesting. Can you check the exact model for us guys? does it clear codes properly? Would love to see if i could clear my airbag light with it. Would be worth every cent.
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/#findComment-7351577
http://www.ebay.com.au/itm/2014-LAUNCH-Creader-VII-Auto-Car-OBD2-Code-Reader-Scanner-Engine-Airbag-ABS-/201094900479?pt=AU_B_I_Electrical_Test_Equipment&hash=item2ed230aaff&_uhb=1
that is a ebay link
and here has more details on various types
http://www.launchtechusa.com/assets/products/products.html
I cant vouch for doing a airbag light but has worked on my fathers land rover a subaru and a bmw i have used it on so far my model is Viii+ but for its price its awesome home workshop addition
  • Like 1
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/#findComment-7352282
  • 4 years later...
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
