Hi guys,
What am I selling:
Make: Nissan Skyline
Model: R34 GTT
Year: 1998
Body: Sedan 4 Door
Transmission: Auto
post-99208-0-53144200-1405800076_thumb.jpg post-99208-0-99949400-1405800733_thumb.jpg
post-99208-0-08044500-1405800868_thumb.jpg post-99208-0-15352100-1405801201_thumb.jpg
Who would be interested:
Some one looking for a project car or parts.
Why am I selling:
I am looking to rid myself of my skyline, I was constantly replacing parts until my girlfriend calculated my end of year mechanic bill and decided to stop. After having the cooling system cleaned and replaced I was driving and the engine overheated. Long story short, I told my mechanic friend what happened and he said it was most likely a purge plug on rear of engine. The part itself is not expensive however the labour to replace the part is more than I am willing to spend. Additionally I do n ot wish to do the job myslef.
Problems:
Cooling system: New purge plug required. (Could be something else, mechanic is fairly certain).
Interior: Leather is peeling, door cards are in bad condition, front seats are aftermarket and not "legal" will need to be replaced for road worthy. (Carpet, dash and gauges are excellent).
Registration: Not Registered.
Condition: Not driving due to heating issue.
Positives:
I did love this car and up until these heating problem mechanically it was A+. Serviced very regularly and maintained very well. The car drove excellently and I miss driving it already. Will not require much work for road worthy, no oil leaks etc.
How much:
Car towing and removel + $800. (Only because I recently put on a new blitz intercooler worth $800).
I was originally going to just have it scrapped because I could not be bothered, however, I know how hard parts for these cars are to obtain so I figured I would offer it and maybe help someone out. I will be having it scrapped in two weeks time so pm me if interested.
https://www.sau.com.au/forums/topic/445844-carins-r34-gtt-1998/
Offer made at $1,000.00 but no deposite. Listing now at $1,000.00 will accept counter offers, however first person to put a deposite down and show commitment to buy will get the vehicle. Please PM if interested.
Edited by Ajorgs
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
