Bride \ Recaro Express Group Buy #2 "replica" Seats Carbon , Kevlar ,frp ,glitter
Ok list updated.
Longz : Bride Stradia Alcantara , Bride Low Max Gias Alcantara
smg084: Stradia 2 Sport Style-frp
lokiR33 : BRIDE STRADIA II - FRP Black
Jezr: Bride Stadia II Maizora Graduation Fabric
BLK-51N : Bride low max gias 2 FRP back in black gradation standard size
green180sx : Bride Low Max Gias 2 - Kevlar purple stitching black floral writing **
amir : i can ask what seat ?
Can any of the styles be purchased individually, or are they all in pairs? If you tell me which ones I can buy individually I'll have a look and decide.
Cheers
Yeah , check the list of seat's in page 1 let me know which one and ill forward to factory for you.
BRIDE VIOS III - FRP in Red. Are they able to make car-specific rails? If not, how much fiddling around is involved to make these universal rails fit?
Cheers Longz
Also, I am about 180cm tall and I do not want the back "holes" for the harness to be below my shoulders when I sit so I may need the XL size seat?
Cheers
Abdul11 : Bride Vios III FRP Red -
Update : It look's like the factory has space to produce a limited amount of Bride XL seat's is anyone interested before they go to back order again ?
It's probably not possible for me to get the XL seats is it? If I can I will, if I can't all good :)
green180sx : put your order in already think i can't change it lol
NISR : still waiting on confirmation if they can fit a order in i will know in a few days.
Interested in getting a pair, but not too sure which one is which. Can someone please answer my following questions:
1. Is the Vios III a fixed back?
2. which ones are the Stradia II and Low max Gias 2?
3. Universal rails - meaning it'll fit into my 34 gtt with no modifications needed?
I want the one that looks like this: http://image.nengun.com/catalogue/1024x768/nengun-3284-04-bride-stradia_ii_-_low_max.png
and from the link, it says that one is the stradia II. Just want to confirm.
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
