Hey guys, up for sale is my 1993 Holden Barina 5 door (white) 1.3L automatic
I have acquired a VT commodore for cheap so its time to get rid of the 3rd car
125,000km on the clock - wouldn't pay too much attention to that
The good:
6 months rego (January 2015)
Major service just completed including
-timing belt
-engine and transmission oil changed
-air, fuel, engine and transmission filters changed
-spark plugs changed
-changed the front pads and has new brake fluid (also comes with rear pads, but I didn't change them as it didn't need it)
-rocker cover gasket changed
AC is cold
Awesome on fuel, approx. 8L of fuel per 100km around town
Mechanically its sound and hasn't failed me in the time ive had it
The bad:
The body has a few dings in it but nothing too bad
The tappets are a bit loud during start up until the engine is warm when the quiet down. (I have personally adjusted the tappets) Thicker oil should quiet them down
There is a small oil leak from engine, not sure where from as I was never concerned enough to worry about it
Only chasing $990, Awesome little daily
Located Prestons
0432528844 or PM for pics
cheers
    • Hey all, I'm working on a project car and I believe I made some mistakes. I'm looking to remove the clear coat from my car on most panels (except for panels where the paint has blistered, I will sand this), but wanted to know if these steps are correct?   1) Get a red scuff pad (abrasive one) instead of sand paper to remove the shine from the surface 2) get 400 grit sand paper and go over the entire car with a random orbital sander so the surface is smooth and the primer can grab onto something 3) On the blistered paint, go over it with around 120 grit sand paper, go to 240 to smooth out the scratches, then finish on 400 grit. Anything to add in here or any feedback?
    • Agreed, another vote for the Haltech CAN wideband.  No voltage offset errors is a beautiful thing.
    • Just get a Haltech CAN wideband, no need to wire any delay circuits, or relay, etc. Since I've moved to a Haltech CANbus wideband, I have not replaced a single sensor for over 5 years (if not longer, can't remember when moved to Haltach).
    • Small analogue delay circuit with a relay. Just need a trigger, say, fuel pump running for more than 5s or so? Or, you could go full mental and write a sketch for an Arduino.
