I'm currently working on an old R32 GTR with a busted oil pump. It's one of the early models which were notorious for this problem. It starts but never build oil pressure, or so I was told. I haven't attempted to start it myself obviously.
I dropped the oil and it seems fine, no bits and pieces in there; I'm also going to cut open the oil filter and I'm expecting a few chunks of debris. What should I see if the oil pump has kicked the bucket?
I want to do a compression test to make sure the cylinders themselves are okay before I pull the motor out. I plan to change the oil pump and check the bearings to see if they are f**ked too which is more than likely.
So my question is, if the bearings ARE okay (unlikely), would I be doing any damage to them by running a comp test while the oil pump is 100% f**ked? With all the plugs out there isn't much load on the bearings other than on the cylinder being tested.
Any input would be appreciated thanks fellas.
Also if you have any tricks to help get the motor out you might save me a few headaches! I'm planning to leave the trans in. Leave the power steering and AC pumps in but zip tied out of the way, pull the driveshafts then everything else etc.
It can't be nice on the bearings, but the damage is likely already done. Especially as the engine obviously was running to break the pump!
I don't think it will be catastrophic to do the comp test.
It's alot of work removing and refitting the engine without a freshen up. I understand you only want to do do the minimum, and hopefully you can, it's just that a comp test won't tell you if the engine engine is smoky.
How about you do something real crazy and replace the pump with the engine still In the car. My theory is (it is early and I'm tired) you should be able to by just splitting the sump off and dropping the sump down a touch. Leaving everything else still connected. Sounds mental now that I wrote it , but I would still look into it.
that's definitely a possibility, someone else mentioned that before I think. I'm pretty sure to get the sump off completely is a motor-out job. Or maybe its possible with a bit of swearing and skinned knuckles.
If the bearings are toast the motor has to come out anyway. I don't really want to attempt to pull the crank while upside down! haha what a mess.
I just pulled the plugs and put some WD40 then some oil in each cylinder and gave it a crank. It spins up fine, sounds a bit grindy but that could be normal.
I'll head off and borrow a comp tester but even if the result is positive it doesn't instantly rule out every problem as you said. Cheers for the input
Do a leak down test first, then go from there. You only have to turn the motor by hand a couple of revolutions to do it.
Sorry missed your post, I'll look into it. I don't have a tester so I'll have to ring around. but definitely a full leak down would be more appropriate
Edited by Blackkers
I'm definitely going to have a go at changing the pump with the motor still in the car. See how far I get before I'm back asking for help again haha
You wont know if the bearings are any good till you pull the engine. If you pull the engine it wont take much to pull the head and look at the bores (which if it was me I'd be doing anyway, unless you have a borescope to do it without pulling the head)
If your at that stage, you may as well replace rings + hone the cylinders (or further repair)
I dunno, maybe I'm not getting it. But if it was me I'd be stripping it as a precaution if nothing else. Best case scenario is a couple of rings, honing cylinders and new bearings. Worst case sceneraio you'll need some new pistons etc. But at least then you will know for sure its not going to fail
Yeah you're exactly right. I do have a 2nd car at the moment too.
I would love to get the engine on the stand an do it properly, fresh rings, honed bore and fresh bearings, new oil pump and crank collar, HG. timing belt etc. Sounds good!
Changed my mind again haha I'm just going to pull the damn thing out and do it properly. If I went to the effort of changing out the pump and it spins a bearing by the end of my street I wouldn't be happy
I didn't realise the passenger side drive shaft was a half shaft. That side was easy to undo. Can I leave the half shafts in and just unbolt it?
Also is there a trick to removing the drivers side shaft?
Yep take the top fill plug out of the front diff and lever the shaft out from the middle of inside the diff with a large screw driver or similar. If thats too fiddly then drain the diff oil and take the cover off to do the same. Ive tried pulling it from the driveshaft side but never had success. You also wont get the engine out if you leave the driveshaft there so you also need to remove the shaft completely before lifting the engine out, or at least unbolting the hub enough to swing it out of the way. Which you have to do anyway to remove the driveshaft.
Have fun.
thanks man, i got the RHF shaft out using a big screwdriver...it was missing the surclip on the diff end.
i unbolted the passenger side but left it in, my next day off is wednesday ill pull it out then, thanks for the heads up i was about to leave it in
yeah put a jack under the transmission (mainly for safety) and undo the transmission mount. Then let the jack down, make sure the thing doesnt just tilt back, shouldnt do but just in case (safety first) then work out a way to lever the engine/gearbox to tilt it a bit then you can get a long long extension along the gearbox to get the bolts
It's much easier to do this with more than one person
awesome thanks for that, I've got saturday off so ill get at it then. Then it's time to pull the engine finally.
I was considering doing the opposite and jack up the rear of the gearbox to reach the bolts down the back of the firewall but theres no way that's easier
I picked up an R34 rb25det neo oil pump today. supposedly these are the same as the N1 units, should do the job
As mentioned, a couple of long extensions. I put a flexi joint at the socket end also. Be aware as you drop the gear box down it weighs about 90 kgs. You also need to twist it clockwise (when facing front) before sliding it back to to allow the starter motor hump-housing to clear the body. Dont drop it on yourself- have another person to help (plus a couple of jacks), it will be a lot easier. Also undo the tailshaft flange off the box to allow it to drop enough and slide backwards. Make sure its a push type box and clutch still (if its pull type you need to release the throw out bearing before the box will come off). You might find it easier to get the engine out if youve taken the clutch off as well, and dont forget to remove the gearstick before dropping the box.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
